Gas Gague Issue
Old Jul 19, 2012 | 07:04 AM
Curts1970cutlass's Avatar
Gas Gague Issue
Installed my Gauges last night. Upon installing i noticed the needle for the gas gague was far left past the "E" almost 90 Degrees too far left. The needle will still move when the key is turned but its refrence to Empty is way off point. Is there an adjustment or is something internal screwed up?
Old Jul 22, 2012 | 08:23 AM
1969oldsH's Avatar
IYAOYAS
improper wiring can cause that to happen as well i believe. my issue that i had with my cutlass was when they put the fuel sensor in the tank, it got snagged on itself somehow and caused it to read full. after fiddling with everything besides the tank. i finally dropped it to find the problem. idk how often of a problem this is but if its your last option, it wouldn't hurt to check.
Old Jul 22, 2012 | 08:51 AM
chadman's Avatar
It probably has a short to ground somewhere.
1yesfan
Aug 4, 2015 06:40 PM
Dead Reckon
Jul 14, 2014 02:35 PM
Svu0312
Jan 20, 2014 08:31 PM
HonestDave
Oct 6, 2012 11:19 AM
millwrightrice
Aug 27, 2007 08:13 PM
