Fans
Old Sep 28, 2012 | 04:18 AM
Al Graaf's Avatar
Formerly "Shimmer"
Fans
I would like you's guys opinion on the electric fans. What are the performance differences between the flat blades and the sprial?
71 442-would like to install a small helper fan while leaving the original fan in. What do you guys in Texas do?
Old Sep 28, 2012 | 09:05 AM
Lady72nRob71's Avatar
This guy uses only the stock 6 blader with a working clutch and shroud n seals in place.
Old Sep 28, 2012 | 03:49 PM
Al Graaf's Avatar
Formerly "Shimmer"
Guess if it works in Texas then it should work in Kentucky. Patton says the original system if correct should work as well.
Thanks Rob!
Old Sep 28, 2012 | 04:34 PM
I use a flex fan with no shroud. If your cooling system, flex fan clutch, etc.. is working properly you should be fine. Is your temp too hi?
Old Sep 30, 2012 | 07:49 PM
cwracer's Avatar
This comes up from time to time so I just repost my shots. This is from Flex with shroud and 2 speed thermostat. I can sit in Florida traffic, mid August, with my A/C running, no problem.
Wyze
Sep 10, 2010 01:07 PM
oldspartsgirls
Jul 14, 2009 07:16 AM
koolbreeze21
Jul 13, 2009 05:12 AM
chris83
Jun 13, 2009 08:16 PM
oldjunk
May 1, 2009 03:10 AM
