F85 vs Dynammic
F85 vs Dynammic
Heyo! So my buddy has a 1963 F85 and he said if I want any parts I could have them for my 64 Dynammic 88.
Are there any part similarites?
I'm looking for more like suspension and brake stuff but if anything is the same lemme know
Thanks, Alex
Thanks, Alex
Absolutely NOTHING interchanges --- the 1961 - 1963 Cutlass / F85 are " toys " compared to the
1964 - 1972 Cutlass / 442 etc. --- and even more so compared to Full Size OLDSMOBILE s....
You will encounter serious " road blocks " trying to obtain Front End parts for a 1964 OLDS.Dynamic 88 through conventional channels / auto parts stores --- most of those parts are Discontinued / Obsolete.....
I have all the Front End components --- Upper & Lower Ball Joints, Upper & Lower Control Arm Bushings, Tie Rods & Sleeves, Center Link & Idler Arm (all options / choices), & The Rest....
U.S.A. made vs. Some of the Chineseum reproductions/ garbage.....
I also have absolutely everything for the Brakes --- Master Cylinder, Wheel Cylinders, Brake Hoses,, Brake Shoes,, Brake Hardware,, Wheel Bearings and Seals, BRAKE DRUMS, Emergency Brake Cables
& more......
Always best to simply call me --- 516 - 485 - 1935 --- Craig.....
& more......
