Is this extra MSD mess required to run?
Old Feb 20, 2022 | 01:45 PM
GN1220's Avatar
Do I need the 6AL box and tach box to run this distributor? This wiring is atrocious and I want it all to go away without replacing the distributor if I don't have to.
Old Feb 20, 2022 | 01:50 PM
70sgeek's Avatar
'72 Cutlass ragtop
if you have one of their 3-wire Ready To Run distributors (such as the p/n 8529 for SBO) then no - you don't need the 6AL, and possibly not the tach adapter either depending on the tach itself - you need to provide more details as to what it's all wired to for any more real potential help though.
Old Feb 20, 2022 | 01:56 PM
GN1220's Avatar
That's part of the problem, I have no idea. Can't see any part number on the distributor and it looks like a 1st grader wired it up. Running the factory tach.
Old Feb 20, 2022 | 02:00 PM
70sgeek's Avatar
'72 Cutlass ragtop
you probably wouldn't have an issue running the factory tach off an MSD Ready to Run distributor - they're a simple 3-wire hookup essentially same as a factory unit, albeit it's electronic inside. Google the 8529 so you can see what it looks like inside and out - then take your distributor cap off to see if it looks about the same = that may help you a bit.
Old Feb 20, 2022 | 02:12 PM
GN1220's Avatar
Thank you, I will do some more investigating.
Old Feb 20, 2022 | 02:24 PM
fleming442's Avatar
See if you can locate the wires coming out of the distributor base. If there's only 2, then you need the box(es). If there are 3, it may be ready to run or e-curve. If it's a 2, pro billet, i need a good, used base.
The wiring is pretty simple; if just needs cleaned up. Is the car a G-body, 82-88? I've only seen the tach adapter on those. If not, they may not have hooked the tach up correctly. It should be right on the side of the 6 box. The instructions are online; try Summit.
Old Feb 20, 2022 | 02:33 PM
GN1220's Avatar
It's a 72 U code (factory 455) Supreme with a factory Ralley Pak
Old Feb 20, 2022 | 02:39 PM
GN1220's Avatar
2 wires, purple/black and orange/black.
Old Feb 20, 2022 | 02:42 PM
fleming442's Avatar
That's a pro billet. I'll buy it from you.
To replace, you need an HEI unit or poins distributor and coil setup. That's personal preference and/or year requirements for OCA shows.
Old Feb 20, 2022 | 02:49 PM
GN1220's Avatar
HEI won't fit. I honestly have no idea what this is worth nor do I know what a stock distributor will cost. If it's like anything else I've priced probably super rare and $1,000.
Old Feb 20, 2022 | 03:49 PM
RetroRanger's Avatar
72 Olds CS
You can get a carb spacer, modify your original air cleaner or there is anoffset aircleaner base available to fit an HEI.
other options include original distributor w points or electronic conversion, or some aftermarket distributors have a small cap like the OE
Old Feb 20, 2022 | 04:13 PM
70sgeek's Avatar
'72 Cutlass ragtop
The MSD 8529 is a small-cap 3-wire drop in if you're not interested in a later-model OEM-style HEI - I have plenty of room for it on my '72 350 (Edelbrock 2711 intake) and I assume you'd have similar clearance on the 455 - It would probably also be compatible with your rally pack tach without the adapter box.
Old Feb 20, 2022 | 04:38 PM
66_Jetstar's Avatar
It would probably take only a couple hours to clean that up. I really like the rev limiter with my 4 speed..
If you're not looking for the numbers distributor then any olds points distributor would work and could be bought and rebuilt for cheap.
Old Feb 20, 2022 | 04:47 PM
GN1220's Avatar
At this point I'm wanting to clean this up and get the car ready to sell. Everyone says an HEI won't fit with an Edelbrock Performer, which is what I have, so I guess I need a stock distributor, even though I have an HEI on the bench.
Old Feb 20, 2022 | 07:17 PM
GN1220's Avatar
Shoot me a pm with an offer for the distributor and box.
Old Feb 20, 2022 | 10:54 PM
I know for a fact HEI will fit a performer intake. No problems whatsoever.
Old Feb 20, 2022 | 10:55 PM
I have run the factory Rally Pac tach with the MSD 6AL with no problems. No need for the tach adapter.
Old Feb 20, 2022 | 10:58 PM
Where is the ignition box mounted? If you take the time to do it right, it’s pretty easy to have the box and keep the wiring neat and tidy. The problem is most hacks either are to lazy or impatient to do it neatly.
Old Feb 21, 2022 | 07:18 AM
GN1220's Avatar
Right now it's up under the fender by the battery. I just want a clean, original look and I think all of the MSD parts are unnecessary. This is no race car and I honestly can't believe the MSD system is a huge improvement in this application.
Old Feb 21, 2022 | 08:50 AM
GN1220's Avatar
Apparently I had the Performer confused with the 04B when I was doing research and was told the 04B won't fit with the HEI. So the HEI WILL fit with the Performer 455 I have now but might require modification to the rear of the air cleaner base for clearance. Am I finally on the right page? lol
Old Feb 21, 2022 | 09:42 AM
72 Olds CS
Yes re aircleaner
if youjust want to sell it spend a couple hours to clean up the wireing and callit good
Old Feb 21, 2022 | 09:33 PM
The rev limiter is a nice feature, and longer ignition point life is a added bonus (not that it matters in your case) but I agree, for 99% of the people who just drive the cars, the aftermarket ignition isn’t needed.
Old Feb 22, 2022 | 05:35 AM
GN1220's Avatar
Everything is removed and posted in the for sale section. I'm sure someone can use this stuff, make an offer!
Old Feb 22, 2022 | 05:38 AM
GN1220's Avatar
Yes re aircleaner
Better already. Now to degrease and power wash. Even found the original battery hold down under the battery. 🙄
Old Feb 22, 2022 | 05:47 AM
72 Olds CS
Looks good
if you dont know a vacuum reservoir attaches to the two holes in the firewall just left of the voltage regulator
Old Feb 22, 2022 | 07:41 AM
GN1220's Avatar
Looks good
Thought that was A/C cars only? This is a non-air car.
Old Feb 22, 2022 | 09:51 AM
72 Olds CS
hmm i dont know that. The holes in your firewall have definitely been used tho
Old Feb 22, 2022 | 10:23 AM
GN1220's Avatar
That's where they drilled holes for the coil.
Old Feb 22, 2022 | 09:33 PM
Why wouldn’t they have used the factory coil mounting bracket? Guess they wanted to show off their newly purchased go fast parts?
Old Feb 23, 2022 | 04:39 AM
tru-blue 442's Avatar
Old School Olds
Let me know if you need one of the off-set breathers that has the indention for the HEI. These were offered in 75-76 models.
Old Feb 23, 2022 | 09:11 PM
  #31
GN1220's Avatar
Just put the air cleaner on and it fits the the Performer intake and HEI. Thank you for the offer though.
Phoenix8990
May 16, 2021 04:08 PM
724drcutlass
Nov 10, 2020 11:50 AM
JoeBirmingham
Jul 31, 2019 02:25 PM
Peter Lufrano
Jun 16, 2017 06:01 PM
akins2000
Apr 22, 2014 02:48 PM
