exhaust manifolds
Old Jan 16, 2019 | 03:40 AM
deadeyejedi's Avatar
exhaust manifolds
will be trying to fire up my 455 in the coming weeks and im working on setting up a temporary exhaust system .i have a bunch of left over stuff from my other cars so i was going to set up a single exhaust with crossover pipe .i believe i have a right side 455 manifold and left side 350 .what exactly are the differences between the two ?and is there a way i can identify the numbers on them to be sure what i have ?thanks
Old Jan 16, 2019 | 04:05 AM
toymobile's Avatar
If the set up is temporary it shouldn't matter, The bolt holes are all the same, the 455 will have a slightly larger port opening than a 350.
Hope this helps, Good luck
Johnny
Old Jan 16, 2019 | 05:16 AM
Back in the day I put a Olds 350 in a 1968 98 which had a 455. I went to hook up the original single exhaust pipe up to the manifold and found they didn't match but all I had to do was elongate the holes on the flange and it bolted up and never leaked. Amazing how that low compression 2 bbl 73 350 lugged around that barge. It was my winter beater a couple years. I was the only guy around with a 455 Olds in a Omega and a 350 Olds in a 68 98. Good times... Keep us posted on how your engine runs.
Old Jan 16, 2019 | 06:16 AM
As with cylinder heads, SBO exhaust manifolds have ID numbers, BBO manifolds have letters. The SBO manifolds are more restrictive, which won't hurt anything for a temporary installation.
Old Jan 16, 2019 | 06:22 AM
Thanks for the replies .will continue forward
sammieolds
Dec 3, 2016 09:05 AM
yankees
Jul 23, 2014 11:52 AM
47 Convertible
May 19, 2012 04:00 PM
ELECMAN
Mar 15, 2010 10:50 AM
cowboyup1248
Jan 23, 2009 01:25 PM
