is the exhaust manifold gasket on 403 the same as 350 gasket?
Old February 14th, 2013, 01:47 AM
aussiemobile's Avatar
does anyone know if 350 are the same as 403? cheers
aussiemobile is offline
Old February 14th, 2013, 08:19 AM
Well, neither of those used a gasket from the factory, but EVERY SINGLE second gen Olds V8 from 1964-1985 uses the same exhaust gasket, if you choose to use one. Only the roller-cam 307s with the peanut-port 7A heads use a different gasket.
joe_padavano is offline
Old February 14th, 2013, 06:20 PM
thanks joe , pontiac olds engine parts are easier to get over in australia cheers
Old February 15th, 2013, 07:31 AM
Um...
Just so we're clear, Oldsmobile and Pontiac motors are completely different. An Olds 350 (and 403) uses exhaust gaskets that look like this:
Pontiac 350s use gaskets that look like this:
Chris289
February 10th, 2015 12:17 PM
Kennybill
October 13th, 2013 05:09 PM
abram
October 15th, 2009 11:08 AM
slumpy
July 29th, 2009 11:28 AM
jeffreyalman
June 6th, 2009 06:28 PM
Quick Reply: is the exhaust manifold gasket on 403 the same as 350 gasket?
