Engine tick? My motor is not purring
I hear a ticking coming from the drivers side can't tell If its up top or down bottom. Please help how can I tell if its a loose rocker arm?? Is it my oil? 10w-40 high milage?? On a low milage motor. I've tried Lucas oil but no help. Thanks in advance. Oh and the car sounds like a diesel truck in the morning
A 'tick' is usually associated with a collapsed
lifter, mushroomed or bent pushrod, loose rocker
or a combo of all three.
If it sounds like a diesel, your timing may be way
to far advanced. I would pull the valve cover
and do an inspection. Depending on where you live,
10-40 maybe a little thin. I personally use Vavoline
30 weight racing oil. No need to add zinc, it's in there.
You can use a rubber hose like a stethoscope to chase down a ticking noise. The diesel noise may be a sign of a lifter issue relating to your ticking noise. I would start by pulling the valve cover off on the noisy side and investigate loose or worn rocker assy's. 10w40 should be fine for your engine.
dont forget, a ticking sound can also be a (or many) loose exhaust/header bolts.
this happened to me, i couldn't diagnose the ticking for the life of me. turns out i lost a header bolt and there was a slight leak.
I had a thread awhile back when i was trying to rip apart my valvetrain, cleaned it all, put it back together, tick still there.
I went to a car show and an old timer told me "Son, you're missing a header bolt, might make that tickin' go away"
Sure enough, problem solved.
