Engine Swaps
Engine Swaps
i have a buddy that has put in a 305 78'camaro engine in a 87 cutlass. now everything so far looks good except when we put on the starter it doesn't match up! it is off by about 1inch. my question is what starter would fit this swap! we have heard that several starters are available for it like a 83 Chevy but we arent sure what type or model. i will insert a pic to demonstrate!
confusion
ok to clear it up. The engine came out of a 78 camaro and was installed in a 87 cutlass. the tranny from the 87 cutlas is still installed and will not be moved yet! i just need to know what starter i could put on it to be able to get the starter to turn the flywheel! that is my problem so far! to get the starter to turn the flywheel! it is about 1 inch off from engaging the flywheel!
Yes there are two different flexplate/flywheel sizes for chevy.
Also two different starter nose lengths.
Also two different starter mounting bolt configurations-straight across and diagonal.
14"flyweels have 168 teeth- (51% chance you have this one)
12-3/4" flyweels have 153 teeth.
flatoz
January 28th, 2009 12:37 PM
