engine swaps.
Old Aug 30, 2010 | 10:34 PM
loosecannon39's Avatar
Cool engine swaps.
New project in the works. Need some advice.
Of the 303/394 series engines, what is the latest / largest that will bolt in to a 50 Olds coupe without frame adapters?? Trying to get by with just swapping stock parts if possible... Lots of nostalgia in this project.
I also want to use the early GM 4spd hydro, so I will sacrifice some engine size if this tranny bolts up, since it will be for cruising, not racing........
Tks for any help..
DAN
Last edited by loosecannon39; Aug 30, 2010 at 10:37 PM. Reason: incomplete wording
Old Aug 30, 2010 | 11:14 PM
88 coupe's Avatar
Junior Member
303, 324, 371, 371, and 394 engines will bolt in using '49 - '50 mounts.
I do not do trannys but '49 - '56 (not '56 Jetaway) Hydro will bolt up if the bell housing and flywheel for the trans is used. Flywheel must be transfer balanced using the '371 - '394 (externally balanced) unit.
Drive shaft should be the same length, but the yoke will need to be changed to fit a newer trans.
Left exhaust manifold exit flange was too close to the steering box, so I adapted SBC headers.
Norm
Old Sep 2, 2010 | 02:38 PM
okie88's Avatar
Google ' 1956 Oldsmobile '. The 5th selection down, titled '1956 Oldsmobile' is a detailed explanation of a 394 swap into a 56 Olds, using the early trans. I think a lot of the steps will be the same when installing the later motor in the 50 Olds.
Old Sep 2, 2010 | 02:44 PM
64Rocket's Avatar
What "Okie" said................................ Pretty much the same frame......
Gene
madmax442
Non-Olds Engines
176
Sep 13, 2021 05:54 AM
loosecannon39
Aug 10, 2012 12:56 PM
gearheads78
Non-Olds Engines
Dec 3, 2010 07:55 PM
flatoz
Jan 28, 2009 11:37 AM
Orlandoanido
Jul 14, 2008 08:17 AM
