Engine RPM.. Is it me!!
Old Sep 20, 2011 | 12:20 AM
aristellier's Avatar
Hi all, just a quickie, I have a '63 Starfire, driving at 50mph the engine is doing around 2600rpm is it me or is this a little high? The transmission appears to change into top gear ok. The car does have 20" rims on it but I would have thought that this would have lowered the rpm. I have checked that the speedo is give or take right by comparing speed to a sat nav. I haven't had the car long enough to really check the fuel consumption as I have not taken it on a good run yet. I previously had a '63 Dynamic and I don't remember it revving anywhere near this. Any ideas as to what it should be revving at?
I would appreciate any information thanks.
Old Sep 20, 2011 | 02:13 AM
72 cutlass455's Avatar
2600 rpm sounds close to what it should be at highway speed.
Old Sep 20, 2011 | 02:24 AM
svnt442's Avatar
It all depends on what the gear ratio in the rear end is along with the tire diameter, not the rim diameter.
Old Sep 20, 2011 | 04:00 AM
rocketraider's Avatar
Oldsdruid
2600-2800 is close on a Starfire. Those have 3.42 gearing. Odds are your 88 had 2.73-3.08 range.
Old Sep 20, 2011 | 11:28 AM
Tyre diameter is 28". Perhaps it is just me then. The exhaust is noisier so perhaps can hear more than I did before. Thanks guys for putting my mind at rest.
skubydobdo
Feb 3, 2014 03:25 PM
66ninetyeightls
Ninety-Eight
Sep 13, 2011 12:18 PM
rick_roach
Nov 3, 2008 03:57 PM
W30post
Nov 30, 2007 02:46 AM
