Engine pics
Great engine pics. I need the motivation too. Waiting on the heads to come back from the machine shop then resume assembly.
I am thinking of going with a scheme similar to Alex above. Gold block, chrome valve covers, and unpainted Edelbrock Performer RPM intake.
I cobbled it together. See link below for a better description.
d1
https://classicoldsmobile.com/forums...ir-scoops.html
d1
Yes I'm using the 2" ones. I would have preferred 1 7/8s but the header flange dictated 2" for a better match. The exhaust ports on the heads are pretty big and 'D' shaped.
I have not even tried my starter yet but it's a RobbMc model so I can clock it in any position. It will be awhile before I get to that point. Right now I'm working with a 1.7 HS rocker to see if the 3/8 push rods will clear. If not it will be 1.6 HS
Have you measured the pushrod length? Do you have pushrods? I have a set of 3/8" oil restricting pushrods 9.8" long that I'll sell for a little over half the cost. They are brand new...
Also, good score on the Bulldog heads...what do those run when you can get them, if you don't mind me asking
I think I'm going to need push rods in the 10.25-10.5 range. I know the valves are taller than stock by roughly 1/2 inch. Once I find out for sure I'll let you know.
3kish, I'm still doing the math lol.
