Engine knock
Old Mar 16, 2011 | 07:47 PM
CaliCutty26's Avatar
Engine knock
i have a 85 cutlass with the 3.8L v6 and it started to make a knocking noise. This has happened once before, and it showed a low oil temperature. This time around, the low oil light has not come on, the car does not overheat, nor does it shut off. I was wondering if you all could help in deciphering this mystery? Thanks in advance.
Old Mar 17, 2011 | 10:46 AM
Is your oil level ok?? Is it a knock or a tapping noise??
Old Mar 17, 2011 | 12:29 PM
the oil level is ok, and its a knock...i was told that it was my lifters. :/
Old Mar 17, 2011 | 01:04 PM
oldsguybry's Avatar
NOVICE car nut
I thought if it was a tapping noise , that it was the lifters , and if its knocking , it is usually in the lower motor such as the wrist pin on the connecting rod.
Old Mar 29, 2011 | 07:12 PM
Rodbo's Avatar
Some of those 3.8L v-6 engines that sit cross ways had a weak point at the harmonic balancer that would come loose and rattle and sound like a rod knocking.
BangScreech4-4-2
Feb 25, 2015 11:18 AM
delta_88_germany
Non-Olds Engines
Sep 28, 2014 05:44 AM
delta_88_germany
Brakes/Hydraulic Systems
Nov 2, 2013 05:06 AM
805cut
May 25, 2012 03:30 PM
walkthwalk92
Jul 21, 2009 08:30 AM
