Engine Doesn't Turn Over In Park, But Does In Neutral
Old Apr 2, 2023 | 12:53 PM
442dale's Avatar
Hello Guys,
I am finally putting together my 1970 442 Pace Car Convertible (10 year complete restoration) and am almost ready to start the rebuilt engine. I replaced the Dual Gate Shifter with a new unit (Parts Place) and removed and relocated the Neutral Safety Switch onto the new shifter unit.
The engine will only crank when the shifter is in neutral and won't crank in Park.
Any ideas?
Old Apr 2, 2023 | 01:22 PM
redoldsman's Avatar
Proud Viet Nam Veteran
Switch probably needs adjusting.
Old Apr 2, 2023 | 01:27 PM
Exactly. That is a switch issue
Old Apr 2, 2023 | 01:38 PM
442dale's Avatar
I assumed that it was a switch adjustment but there is only about 1/4' of adjustment and that didn't work.
Moving it side to side over to one end stopped it from starting in Neutral so it seems it likes only one spot.
But nothing happens in Park.
Old Apr 2, 2023 | 01:40 PM
Did you verify that the switch makes contact in the PARK position? This could be an adjustment problem or it could be a bad switch. Why did you replace the original dual gate with an aftermarket one, which may or may not be manufactured correctly? Are you sure the cable is properly adjusted?
Old Apr 2, 2023 | 01:43 PM
Put in park, twist barrel of steering column to max left, see if it cranks. If so, it is not the switch.
Old Apr 2, 2023 | 01:53 PM
442dale's Avatar
Already tried moving the column all the way to the lockout position with the same result.
Joe - Is there a cable adjustment procedure that I should have followed?
It was 10 years ago that I tore everything down and the car did start in Park so I'm not thinking it is a bad switch.
It is a new cable as well as a new shifter unit.
Old Apr 2, 2023 | 02:16 PM
If the switch is on the shifter, how does moving the column play into this. As Joe said, it may be a bad switch or an adjustment since it does start in neutral.
Old Apr 2, 2023 | 02:33 PM
Same way it does for the ones on the column.
Old Apr 6, 2023 | 01:19 PM
442dale's Avatar
The culprit was a very slight difference in the new shifter unit in relation to the available adjustment of the Neutral Safety Switch. When I proved that theory out, I just needed to elongate the two holes so it would move back just a bit more and make contact inside the switch when in Park.
Thanks for everybody's replies.
Old Apr 6, 2023 | 02:16 PM
Well done, glad you got it adjusted.
jesse.havlik
Sep 21, 2018 08:12 AM
Faherty442
Jan 3, 2015 11:24 AM
navvet
May 12, 2013 12:23 PM
Promethean
Jul 16, 2012 05:13 PM
OhMyOlds
Aurora
Oct 21, 2007 12:44 AM
