engine
Old May 7, 2012 | 04:04 PM
jchavis44's Avatar
Lightbulb engine
hi just bought my first old skool 1965 delta 88 and i can't figure out wat size motor is in it...i looked everywhere on the motor but all i could find is the serial #411990
Old May 7, 2012 | 04:14 PM
Seriousfun's Avatar
*ssholes Garage
Welcome, someone on here knows where to look
Old May 7, 2012 | 04:19 PM
Oldsmaniac's Avatar
It is a 425, you wont find the size anywhere but be assured it is a 425.
Old May 7, 2012 | 04:24 PM
Oldsmaniac's Avatar
To elaborate some, it should be a D block. The heads should have a large A stamped on it. The block should be a reddish orange. It could be a HC or low compression engine. Standard issue was the HC 2bbl carbed engine with single exhaust. The 4bbl was optional as well as the Starfire engine with dual exhaust. All of this will be based on an original engine car.
Old May 7, 2012 | 04:25 PM
jchavis44's Avatar
thanks so much guys.... because by this being my first restore project my brain is scattered trying to find parts for this car and i didn't want to get parts for a motor and didn't no which motor i had.. do you no where i can find the chrome trimmings
Old May 7, 2012 | 04:26 PM
radioburningchrome's Avatar
One would hope it is a 425.
Don't forget people did crazy things to save gas. I have seen 330s and 350s in Deltas and Ninety-eights.
One even had a 260!
Old May 7, 2012 | 04:28 PM
jchavis44's Avatar
who ever had the car before me had a 2bb on the motor with some of the holes plugged off, i found out that it should have 4 bb carb also the block is the same color as the car, baby blue instead of the reddish orange you described
Old May 7, 2012 | 04:37 PM
Oldsmaniac's Avatar
I think a picture is needed.....cause blue paint may be a hint of a swapped engine...
Old May 7, 2012 | 04:39 PM
jchavis44's Avatar
i will upload one in 4 min. let me go take a pic of it
Old May 7, 2012 | 05:26 PM
jchavis44's Avatar
the pic with the screws is wat i meant bu plugged off and the car runs but its a 2 bb carb i no it needs a 4 bb carb
Old May 7, 2012 | 05:27 PM
Oldsmaniac's Avatar
There aint no picture....
Old May 7, 2012 | 05:36 PM
jchavis44's Avatar
i tried to upload the pic and the site want let me. it lets me select the pic then when i press upload the pic dissappears
Old May 7, 2012 | 05:37 PM
Oldsmaniac's Avatar
You have to post in advanced and then click manage attachments... I am in chat if you have a question..
Old May 7, 2012 | 05:44 PM
Octania's Avatar
Bad news and good news sir
Google "Olds* 411990" and you will see that it is the casting number of an EGR era SMALL BLOCK, so your factory 425 is long gone. That intake will only fit on a small block. The #16 intake is the Turd of all SBO intakes- all the EGR-ness of the smog era in a 50 lbs pkg... whereas the fairly common A4 Aluminum version is plentiful and cheap and does the same thing for 30 lbs less weight.
http://www.google.com/url?sa=t&rct=j...zfPGif9y5zOIxg
Try to find a wiki or schooling site that shows where to find the Engine Casting ID- atop timing case, fwd of the intake and aft of the water pump. Scrape the goo away to find the block casting numbers, like "295558 2"- which has a much larger "2" at the end. Find also the huge casting ID CAST INTO the corner of each head, on your left lower corner as you face the engine from aside, Near #1 or #8 cylinder.
Bring us that info.
The blue engine also says smog era. Your picture was probably of the blocked off EGR port, driver side?
So, it might be a 307, 350, or if you are lucky, a 403. If you are REAL lucky, the only Solid Main Web 403 ever to be photographed.
The good news is engine parts are plentiful. Just gotta know what you have there, first.
I have a '65 4-dr for parts, so might have some tidbits; NO sheet metal here in MI though.
Old May 7, 2012 | 05:54 PM
jchavis44's Avatar
Old May 7, 2012 | 05:55 PM
jchavis44's Avatar
Old May 7, 2012 | 05:56 PM
jchavis44's Avatar
Old May 7, 2012 | 05:57 PM
Oldsmaniac's Avatar
The picture shows a lot, newer engine with HEI electronic ignition and EGR and not a 65 carb but it is a 4bbl. Also looks to be a small block as already noted by intake number.
Old May 7, 2012 | 06:01 PM
Octania's Avatar
I see your secondary air valves hanging open, for no apparent reason...
might want to rectify that snafu right away.
appears to be a Cheby [side inlet] carb... with no choke hooked up.
Throttle cable / trans cable bracket lying atop the RH valve cover, doing nothing.... you have a bit of work there to get things squared away.
jchavis44's Avatar
you see in the pic where as he has plugged some of the holes with screws...
Old May 7, 2012 | 06:03 PM
jchavis44's Avatar
i bought it from some guys at a music shop they had a 1966 2 dr convertable also which they said they were going to take the motor out of mines before i bought it and put it into the 66 .....i no i needed a carb and brake booster from the start and those plugged holes just made me think
Old May 7, 2012 | 07:03 PM
I do not have a good feeling about this car.
I believe you Texans have an expression: "Rode hard and put away wet."
I suspect that this car is going to be a true learning experience for you, so why not tell us your name and a little bit about yourself, because I suspect we're all going to become good friends over the next several months, as you peel this onion.
Meanwhile, I'd recommend perusing the Tech section of this site and the Olds manuals on WildAboutCars.com, to get yourself familiarized with everything you're going to have to know .
Old May 7, 2012 | 07:17 PM
ah64pilot's Avatar
jchavis44, there are a few of us Houston boys on this site. If you need any help please don't hesitate to ask. If you decide to do something with the motor let me know and I'll hook you up with my machine shop. They're in Conroe, Nicken's Brothers Racing Engines...
Several of us are starting to link up at Houston area events, maybe one of these days we'll see you there! Good luck!
Old May 7, 2012 | 07:39 PM
Olds_71_442's Avatar
Should be able to look under the passenger side manifold and see a giant "403", "350" or "307" stamped into the block if it's a newer EGR engine. I'm betting it's a 307.
I shouldn't say "stamped".....more like protruding numbers.
Old May 7, 2012 | 08:13 PM
jchavis44's Avatar
thanks guys.....and im 29 on the northwest side of houston and this is my first project car. i admit i don't no alot about cars like most of you, but i plan on learning all i can. and with your help i hope build, trade, explore, sell and show off my rides.
Old May 7, 2012 | 08:18 PM
jchavis44's Avatar
ah64lpilot wat side of houston are u on
Old May 7, 2012 | 08:47 PM
ah64pilot's Avatar
Northeast, close to 1960 and 59.
Old May 7, 2012 | 09:10 PM
jchavis44's Avatar
Im in greenspoint behind the mall
805cut
May 3, 2012 08:11 PM
Olds luvr
Mar 17, 2010 06:57 PM
njot33
Sep 25, 2009 09:07 AM
cts-v
Jan 10, 2009 06:20 PM
pinky
Oct 1, 2007 11:24 AM
