Edelbrock 600 CFM--undersized?
1969 442.
Somewhere along the way, someone replaced the QJ with an Edelbrock 600 CFM carb, and a performer intake. The manual choke is held open with bailing wire. Bitch to start cold. Question--
Original 400 CI, is the 600CFM sufficient to feed the beast? Feels like it doesn't have what it needs. However, it's only on there until I get time to install the Holley EFI QJ kit (early summer?)
edit; I do have the original QJ but it's in a basket and missing parts. That's how I got it. I will have it restored at some point.
It should run ok with that carb for a while. I wouldn't do anything until you get the EFI on it. Your cold start issue probably is not the choke wired open, you just need to operate the throttle until it warms a bit.
![](https://cimg5.ibsrv.net/gimg/classicoldsmobile.com-vbulletin/1500x2000/pxl_20220223_181851223_motion_01_cover_77cfe56de9d2024af729de21da4f530bfed07a20.jpg)
Are the older ones square bore only? Edelbrock's web site says the current ones are dual-flange:
https://www.edelbrock.com/performer-...atin-2151.html
Edelbrock Performer Olds 455 Intake Manifold for 400-425-455 c.i.d. Oldsmobile V8 Engines.
Includes Exhaust Crossover Plugs #2733, which Must be used for Marine and Off-Road.
Accepts OEM or 4150-Style Carburetors.
Non-EGR
Non-EGR
Non-EGR
Non-EGR
Sorry I gave you bad info on the manifold. If it were mine I would send the Q-Jet out and have it rebuilt and then put it on instead of the Holley FI. You will save a lot of money and headaches.
