Edelbrock 600 CFM--undersized?
Old Feb 23, 2022 | 09:42 AM
Bryan Burch's Avatar
1969 442.
Somewhere along the way, someone replaced the QJ with an Edelbrock 600 CFM carb, and a performer intake. The manual choke is held open with bailing wire. Bitch to start cold. Question--
Original 400 CI, is the 600CFM sufficient to feed the beast? Feels like it doesn't have what it needs. However, it's only on there until I get time to install the Holley EFI QJ kit (early summer?)
edit; I do have the original QJ but it's in a basket and missing parts. That's how I got it. I will have it restored at some point.
Old Feb 23, 2022 | 09:48 AM
It should run ok with that carb for a while. I wouldn't do anything until you get the EFI on it. Your cold start issue probably is not the choke wired open, you just need to operate the throttle until it warms a bit.
Old Feb 23, 2022 | 09:51 AM
redoldsman's Avatar
Proud Viet Nam Veteran
The original Q-Jet is probably 750 cfm. If you are going with EFI why would you have the Q-Jet restored? Being a spread bore it is not going to fit the Edelbrock Performer.
Old Feb 23, 2022 | 10:22 AM
I would restore it because it's original to the car and I'm keeping all the original parts, just in case I get an offer I can't refuse from someone looking for originality. It's not a common QJ, from what I gather. The EFI is the Holley Sniper Quadrajet.
Old Feb 23, 2022 | 12:00 PM
Are the older ones square bore only? Edelbrock's web site says the current ones are dual-flange:
https://www.edelbrock.com/performer-...atin-2151.html
Edelbrock Performer Olds 455 Intake Manifold for 400-425-455 c.i.d. Oldsmobile V8 Engines.
Includes Exhaust Crossover Plugs #2733, which Must be used for Marine and Off-Road.
Accepts OEM or 4150-Style Carburetors.
Non-EGR
Old Feb 23, 2022 | 12:56 PM
Non-EGR
My performer is spread bore. Edelbrock 2151
Old Feb 23, 2022 | 01:34 PM
The 2151 will accommodate both square and spread bore flanges.
Old Feb 23, 2022 | 01:41 PM
Not "probably".
Old Feb 23, 2022 | 02:50 PM
Well then I think this is good news--with a proper amount of air/fuel at WOT, I may see a performance increase. Thank you all for your thoughts.
Old Feb 23, 2022 | 02:58 PM
redoldsman's Avatar
Sorry I gave you bad info on the manifold. If it were mine I would send the Q-Jet out and have it rebuilt and then put it on instead of the Holley FI. You will save a lot of money and headaches.
GCH
Aug 5, 2021 06:12 PM
tgilligan
Mar 5, 2018 06:30 PM
OLDScience
May 17, 2013 09:03 PM
OldsManNJ
May 23, 2012 08:20 AM
theoldsrocket
May 22, 2011 11:18 AM
