Dynamat as heat barrier?
I am thinking about doing Dynamat before the summer. I am not concerned with sound deadening. I want it to reduce the heat in the interior. In the summer the headers make the front floor boards really heat up. Can anyone opine on its effectiveness specifically for heat reduction?
Can't give an opinion but here's a little info from Dynamats website under FAQ's. Question #7.
http://www.dynamat.com/faqs_faqs.html#text3089anc
as you I was not real concerned about sound especially on a convertible but believe it or not it made a huge difference, less rumble, road noise from underneath. As for heat same thing, before I could burn my hand touching tunnel now its much cooler.
Steve, what product(s) did you use?
I used a combo of dynamat extreme and dynaliner on top of that. I feel like it makes a big difference. However, with the current cost of that dyna-stuff 2x the already-too-high price of what it was in 2008, i would recommend their lower-cost competitors. Just stay away from any stuff with asphalt, unless you like the smell...
If you are concerned about weight, I just removed the original and put my carpet over the Fatmat. About the same.
something else to try
try the peel and stick roofing underlayment available at Lowes, tar on one side andfoil on the other , peel off the protective paper and stick it down. all I have heard is great results and 108 sq. ft. is under $70. i.e. one friends truck ('50) is quieter at 70mph now than at 40 before. Also available in varies sizes for flashing such as 6 8 and 12 inch rolls and 36 inch wide, cuts easily with a utility knife, no complaints about tar small etc; check it out. the typefor doing around house windows and doors may be a few mils thinner than the roof type, this is used in new home construction as it eliminates nail holes and stays stuck when the shingles are blown off as happens here in Fla. storms, helping to reduce water damage, not sure but I think it may be required by code here now. Dave
smcurro
Paint
January 29th, 2012 02:31 PM
