Dual Feed Fuel line question
Got a holley 670 with the steel dual feed fuel lines. Problem is the rear fuel line is hitting my coil where it is mounted to the intake manifold.
So, if you guys have pics of similar setups indicating what fuel lines you used or where you relocated the coil, I would be interested in see them.
d1
d1
d1
d1
I mounted my coil on the firewall. Search my postings for pics if you want.
You can build a simple little metal bracket on the bottom of the stock coil bracket to move it over or back. You can also bend those dual feed lines quite a bit to clear things or you could also go to a flexible dual feed line. Or you could go to the trouble I did and make your own dual feed line to clear everything.
Del70
Dec 7, 2025 02:13 AM
