drive shaft stripes
drive shaft stripes
1970 442 convertible, i know i saw a thread pertaining {sp} to this but cannot find it. what are the correct colors, placement, and width of the stripes on the driveshaft for the 442 vert? thanks charlie,,,,
As far as width and spacing, I can only go by what I found on my 72 Cutlass S. It has a different set of color bands because it's a 350 and different model year. From what I've been told, the color bands were used to easily identify what drive shaft to put in a car at a glance, like the ident used for the front sway bars for different lines. I used the 'ghost outlines' I found on my car to duplicate the widths and placement as best I could. It's on the car now but here's what it turned out like. BTW you might remember this because you also were concerned that I kept the original Saginaw U-joints.
Anytime Charlie, hope it helps. BTW is your car MT or AT? Curious if I guessed right. When I cleaned my driveshaft (carefully) I never did find a part number stamping on it anywhere. Please post a pic when you're done!
64 CUTLASS KEN
November 22nd, 2010 05:17 PM
