drive shaft stripes
Old Feb 22, 2013 | 02:20 PM
charlierogers's Avatar
drive shaft stripes
1970 442 convertible, i know i saw a thread pertaining {sp} to this but cannot find it. what are the correct colors, placement, and width of the stripes on the driveshaft for the 442 vert? thanks charlie,,,,
Old Feb 22, 2013 | 03:28 PM
jfb's Avatar
jfb
hey buddie if this helps according to gm and i had 2 friends who worked at the lansing plant were used for balancing only.
Old Feb 22, 2013 | 03:34 PM
Pacecar's Avatar
Check the assembly manual. The colors are in that forget which section
Old Feb 22, 2013 | 04:13 PM
Charlie, here's the chart for the 1970 models. More than likely you're looking at the 35M40 112" wheel base for CS 442. I'm not 100% sure but I think the 4A4 was for MT cars.
As far as width and spacing, I can only go by what I found on my 72 Cutlass S. It has a different set of color bands because it's a 350 and different model year. From what I've been told, the color bands were used to easily identify what drive shaft to put in a car at a glance, like the ident used for the front sway bars for different lines. I used the 'ghost outlines' I found on my car to duplicate the widths and placement as best I could. It's on the car now but here's what it turned out like. BTW you might remember this because you also were concerned that I kept the original Saginaw U-joints.
Old Feb 22, 2013 | 07:21 PM
allan,, thank you very much for the detailed information!!!
pacecar,,, jfb thank you also!
Old Feb 22, 2013 | 09:37 PM
Anytime Charlie, hope it helps. BTW is your car MT or AT? Curious if I guessed right. When I cleaned my driveshaft (carefully) I never did find a part number stamping on it anywhere. Please post a pic when you're done!
Old Feb 23, 2013 | 08:46 AM
automatic trans,, i will post a couple pics when done.
Old Sep 23, 2020 | 02:30 PM
JOHNNYOLDS442's Avatar
Olds Specialist LOL
I made my own stripes!
Old Jul 26, 2021 | 03:18 PM
Mr Gadgets's Avatar
You're making great progress!! That frame looks better than new!! Nice work!
JpMotorsports
Apr 2, 2015 10:21 AM
briane
Drivetrain/Differentials
Jan 13, 2013 04:25 PM
briane
Jan 13, 2013 04:22 PM
Frogge467
Mar 24, 2012 11:09 PM
64 CUTLASS KEN
Nov 22, 2010 05:17 PM
