Drive shaft question
Old May 17, 2017 | 08:28 AM
67Rocket's Avatar
Going to a large GM swap meet this week end and I was wondering if the manual drive shaft and also rear end from a 66-67 Chevelle would work in a 67 Cutlass? Also would same parts from a 66-67 GTO work in my Cutlass? Thanks
Old May 17, 2017 | 08:35 AM
RROLDSX's Avatar
Measure center to centre where the universal joints should go and if you find a driveshaft long enough they are not that expensive to get shortened. You just can't stretch them.
Old May 17, 2017 | 09:15 AM
RandyS's Avatar
I know that the drive shaft from a 66/67 GTO will fit.
Old May 18, 2017 | 04:25 AM
68442's Avatar
Another thing to pay attention to is is it an inside or outside snap ring style
I know chevy(Chevelle) is an outside snap ring
Old May 18, 2017 | 05:09 AM
67Rocket's Avatar
Thanks, I hope to find one with a 27 spline yoke already on it.
Old May 18, 2017 | 05:12 AM
Different rear ends have different lengths from the U-joint centerline to the axle centerline, but the axle location and the transmission output shaft location are the same throughout GM for the same series and body type cars with the same transmissions, so the driveshaft and rear end set together should fit, while either one alone may fit.
Old May 18, 2017 | 05:56 AM
Run to Rund's Avatar
Chevy used the small u-joints, about 3.25" vs. Olds 3.63" across.
Old May 19, 2017 | 06:32 AM
67Rocket's Avatar
So if I went with Chevy rear and Olds driveshaft I would need a Olds yoke in the Chevy rear? Thanks again.
70convert
Drivetrain/Differentials
Mar 7, 2019 02:12 PM
Frogge467
Mar 24, 2012 11:09 PM
J-(Chicago)
Nov 23, 2010 07:50 AM
64 CUTLASS KEN
Nov 22, 2010 05:17 PM
68conv455
Apr 11, 2008 11:48 PM
