Drive shaft question
Going to a large GM swap meet this week end and I was wondering if the manual drive shaft and also rear end from a 66-67 Chevelle would work in a 67 Cutlass? Also would same parts from a 66-67 GTO work in my Cutlass? Thanks
Different rear ends have different lengths from the U-joint centerline to the axle centerline, but the axle location and the transmission output shaft location are the same throughout GM for the same series and body type cars with the same transmissions, so the driveshaft and rear end set together should fit, while either one alone may fit.
