Do I need this
Old Sep 8, 2016 | 03:32 PM
Gary M's Avatar
Do I need this
Switching to m22z from t350. 72 cutlass convertible. Will be using repop console shifter and console.
Says it welds to the cross member for Muncie with console
Old Sep 8, 2016 | 03:47 PM
marxjunk's Avatar
thats chevelle only to use a factory "muncie" manual shifter
has nothing to do with a cutlass..at all
the 68-72 chevelles had a special cross member for manual trans cars..the shifter actually bolts to the cross member..that bracket gets cut off is you use hurst shifter in a chevelle because the hurst shifter hits it..
you need the Hurst adapter that bolts to the tail housing like a 442/cutlass...it bolts to the trans and the shifter bolts to it..
you wont use that bracket in a cutlass.
Old Sep 8, 2016 | 03:52 PM
Gary M's Avatar
Should have known
Didn't look like anything I ever saw.
Old Sep 8, 2016 | 04:14 PM
Gary M's Avatar
If I where a millionaire this would be the perfect excuse to buy that 70 Chevelle SS 396 I always wanted but NOOOO. Thanks for the info Marxjunk.
Old Sep 8, 2016 | 06:17 PM
marxjunk's Avatar
haa..buy me one too..cranberry red...
Old Sep 8, 2016 | 07:37 PM
svnt442's Avatar
Is your crank drilled for a manual trans?
Northern Custom Cruiser
Apr 26, 2016 09:23 PM
ah7910
Oct 21, 2014 06:58 PM
coppercutlass
Mar 1, 2013 07:33 AM
