DIY Ceramic - exhaust manifolds
Old February 13th, 2017 | 06:27 AM
rick442's Avatar
Question DIY Ceramic - exhaust manifolds
Hello Everyone,
Looking for advise on coating my manifolds.
Does this hold up well?
Can you recommend a brand?
thanks!
Old February 13th, 2017 | 06:31 AM
I've heard there is a coating you can apply that keeps the manifolds a gray color. I don't recall specifically what it is. VHT Super hot, BBQ grill paint and Hi Temp Engine paint all seem to burn off eventually. Maybe I just apply them wrong though...
Old February 13th, 2017 | 07:44 AM
I just painted the manifolds on my 67 Delta with the High Temp version of Cast Blast. I have not yet fired the motor to bake the paint and thus have no experience yet with long term durability. I sand blasted the manifolds first.
There are water-based versions of the ceramic header coatings (like Jet Hot) that you can apply at home. I have not tried these yet.
Old February 13th, 2017 | 08:24 AM
jozw30's Avatar
I used the POR15 manifold paint and they look the same 6+ years later (I put less than 1,000 miles on the car a year, and they never got wet).
They were new Thornton pieces.
Good stuff.
Old February 13th, 2017 | 08:38 AM
mrolds69's Avatar
X2...POR15 cast manifold paint is the best stuff to use. Put that on my 442 over 15 years ago, it still looks good. I DRIVE my cars and the 442 goes maybe 2K a year. I touch it up on the car with a foam brush every 4-5 if it starts to wear. I run it on my GS's, too. Forget the can life POR mentions. It re-opens easy, not like regular POR. Put it on, run the car like 15 mins or so shut it off... cool...done. Apply with foam brush......it's killer stuff.
Old February 13th, 2017 | 11:24 AM
jpc647's Avatar
Great info. Mine could use a coat, or 12.
Old February 15th, 2017 | 07:29 PM
rick442's Avatar
Thanks for the info!
Old February 22nd, 2018 | 12:31 AM
Gerald Nickels's Avatar
Try High Temp Cast Blast.
Old February 22nd, 2018 | 01:43 AM
EightballZ's Avatar
i used bill hirschs cast iron gray as an aerosol...holds up perfect
raider973
June 12th, 2012 12:27 PM
olds 307 and 403
January 24th, 2012 04:28 PM
442much
April 28th, 2011 07:37 PM
thadican
March 23rd, 2011 07:58 PM
wmachine
March 13th, 2009 07:03 PM
