Disc Brake conversion
I have a "70 442 w/ non power 4 wheel drum brakes and I want to convert to front disc. Will the front brake set up from a car w/ power front disc brakes be the same? keep in mind I want to maintain non power brakes.
The spindles/calipers/rotors are the same for manual and power disk brakes, as are the hoses, hose brackets, and metering valve. Of course you'll need the correct manual disk master cylinder.
Joe - I may be ig-ur-int, but I always thought front disks were only available with a power booster, never as a manual setup. Your post looks as though that's not the case.
I'd be interested to know more about non-power discs on A-bodies, and how often they are seen.
This is one reason why I don't believe factory HP ratings.
Mocephus
October 1st, 2021 09:45 AM
Maverick
Brakes/Hydraulic Systems
June 26th, 2013 08:21 AM
