Differential fluid recommendations
Old Jan 2, 2022 | 07:33 PM
Redjetty's Avatar
First thanks to all those who made suggestions and the fella that gave me actual GM ref. numbers and cross ref. numbers when last week I was trying to figure out what kind of shocks to buy for my 88 olds cutlass supreme classic brougham that has the F41 susp in it. Got shocks done now I am trying to figure out differential oil s for this car. I am having no luck with internet search so I am back turning to the pro's on here.
Its got a 3.08 rear end but do i go with something with additives or not or dont matter? and a 75/90? Conventional oil or sythn for diff. fluid ?? thanks in advance... Rj
Old Jan 2, 2022 | 07:44 PM
66SportCoupe's Avatar
Buy conventional 80-90. Does it have a LSD in it? Some lubes now come with posi additive in it.
Old Jan 2, 2022 | 08:07 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
You lucky Ducky, someone checked off the best options possible on that car. Neither the F-41 or optional 3.08 gears were checked off on my 88 CSC Brougham that I had. If open, either mineral 85W90 or synthetic 75W90 will work fine. Almost no posi recommends synthetic fluid FYI. Most fluid has a friction modifier added, they will say approved for limited slip differentials. I used full synthetic 75W90 and 75W140 with the proper additive with a Trac Lok and Gov Lock in my trucks that see -40 without issue.
Old Jan 5, 2022 | 07:16 AM
Redjetty's Avatar
No, it does not have posi
Old Jan 5, 2022 | 07:49 AM
70sgeek's Avatar
'72 Cutlass ragtop
I use Royal Purple full synthetic 75w-90 in my 8.5" rear - also 3.08 gear but Posi as well, so I also added a separate Posi additive in further precaution.
Good stuff and readily available at any decent auto parts store.
Old Jan 5, 2022 | 09:29 AM
Sugar Bear's Avatar
Does it have a tag on of the diff cover bolts indicating limited slip?
I realize your asking about the diff so there aren't any yellow metals...Recently had to source (special ordered) GL-4 for a '60 manual transmission to avoid GL-5 and what it can do to synchronizers (yellow metals). Many gear lubes said GL-4 and 5 compatible but I wasn't chancing it on this car.
Stubborn_51_88
Brakes/Hydraulic Systems
Jun 25, 2020 02:18 PM
83Hurst#1812
Drivetrain/Differentials
Oct 31, 2014 09:30 AM
Dick T
Oct 14, 2013 03:36 PM
blleach
Tech Editor's Desk
Feb 20, 2012 05:43 AM
NightStalker
Jan 1, 2011 08:37 PM
