Different castings on C heads
Old Apr 29, 2009 | 12:58 PM
2blu442's Avatar
I have a question about C heads. I've seen them with both small oval holes for the heat crossover and large rectangle holes like other heads. Anybody know why the factory cast some with the small ones and large rectangle on all the other heads? John
Old Apr 29, 2009 | 01:29 PM
OK, you got me on that one. I had never seen that before. Is one a CA head instead of a C head?
Old Apr 29, 2009 | 01:53 PM
citcapp's Avatar
New one on me, I have only seen the larger holes
Old Apr 29, 2009 | 06:48 PM
2blu442's Avatar
The small crossovers are C's that came off a 1968 Toro engine. I have seen at least one other set that I pulled a set off a 1967 425 engine. They only have a large C in the casting, is the Ca like the Ga and Ka heads with a small capitol letter down low on the right? Here's the casting letter and the casting numbers. The numbers look to be the same as well.
John
Old Apr 29, 2009 | 08:22 PM
Danny Wiseley's Avatar
I have a couple of sets with the small hole. One pair came off a '68 98, but I'm not sure what the other set was on.
DW
Old May 2, 2009 | 11:12 PM
Run to Rund's Avatar
Later lettered heads have the big hole so I expect the C heads with the big hole are late 60s. The C heads I have came off 67s mostly and they have the small hole. I guess the factory went to the big hole for easier removal of the sand core.
Old Sep 26, 2013 | 03:34 PM
Chesrown 67 OAI's Avatar
I'm with Rund -- all of my 67 C heads have small holes and i have a set of 68 C's off of a LS 400 that have big holes.
I stand corrected --- I just rechecked my C heads from the LS 400 and they do have the small holes too! Now you got me curious to check my Bs, Es, and Gs that i also have on the shelf!!
Old Sep 26, 2013 | 05:28 PM
66-3X2 442's Avatar
The Ca heads have hardened seats or that's what I have been led to believe.
Old Sep 26, 2013 | 07:34 PM
You were led wrong. The hardened seats started with the 1971 model year. The small "A" does NOT mean "hardened seats", despite the urban myth (or would that be the garage myth). J heads have hardened seats, but they are not JA heads.
Old Sep 27, 2013 | 07:00 AM
66-3X2 442's Avatar
I had a 69 455 that went into a 66 442 for a buddy of mine. It had Ca heads and I told the machine shop to put hardened seats in the heads. They said the seats were already hardened from the factory. The parts book I have lists two different part #'s for bare 69 big car heads,I wonder what the difference was? I yield to your expertise.
I went back and checked an earlier parts book on WAC and it has heads listed as far back as 65 with hardened seats. There is a 230991 part # for 67-69 heads with hardened seats on irrigation engines. So I guess that shows that hardened seats were used before 71. Did the hardened seat heads find their way onto passenger cars,your guess is as good as any.
Old Sep 27, 2013 | 08:15 AM
Hairy Olds's Avatar
Shoveling Snow
If you have a Ca head with hardened seat their most likely off of a irrigation engine that was destined to be run on propane or natural gas. No lead in those fuels to lubricate the seats.
Old Sep 27, 2013 | 08:24 AM
66-3X2 442's Avatar
The engine with the Ca heads came out of a 69 big car. I have no idea if it was original or not but it looked like an unmolested original car. Again,I was going by what the guys @ the engine shop told me about the heads already having hardened seats. If there are Ca heads out there off passenger cars and the irrigation engines having hardened seats,is it possible they used them for car applications too? Like I said in my previous post,the parts book lists two different part #'s for 68-69 big car bare heads,why is that? Come on Paul,get in the parts book and tell us why. I love investigating these abnormalities found with these cars.
Old Sep 27, 2013 | 09:38 AM
Bernhard's Avatar
X2 early C heads small heat riser late C heads large heat riser
Old Sep 27, 2013 | 11:56 AM
CANADIANOLDS's Avatar
nothing special about the two different size heat crossover sizes....all early heads A B and early C's had small ones. so olds engineers in there infinite wisdom descided to supply more heat to the intakes in later C heads, and all heads besides the partially blocked W castings ..funny thing is all small blocks from #1 onward had the larger hole.
as far as the manual having two different part #'s for C heads i think that would be because big or small int valve..
Old Sep 27, 2013 | 01:24 PM
Mikes442's Avatar
I have a pair of CA heads that have the larger hole. All my other C heads have the small hole. I did notice that on the block side of the head on the left side my C's have 548 and the CA's have 48A. They look like big valve heads. I will take them to my machinist and have them checked for hardened seats tomorrow (Sat).
Is there any way of finding a year code on the C's besides the crossover hole?
Mike
Old Sep 27, 2013 | 01:27 PM
Mikes442's Avatar
The CA heads have the capital letters the same size and straight across.
Mike
I got to learn how to post pic's!!!!! LOL
Old Sep 27, 2013 | 02:16 PM
66-3X2 442's Avatar
Mike
Mike
See if the seats are hardened by heat or have inserts. What I mean by heat is,the pocket and the seat area itself will have a blue look like it was heat treated. This may help us with this discussion.
Mike
Old Sep 30, 2013 | 12:56 PM
Mikes442's Avatar
Mike
He was gone on Saturday to a wedding.
Took them in today and he said they didn't have inserts.
He said that they might be heat set. I told him to clean and check to see if they were hardened.
He said the hardness would only be about 5 thousandths deep and would need to be cut to keep the hardened seats back in.
I told him just check one seat that looks bad and don't put any in.
Mike
Old Oct 1, 2013 | 02:52 PM
BlackGold's Avatar
I guess I'm not too surprised to see two supposedly identical heads with a non-identical feature. The size of the crossover passage was probably considered non-critical.
In a similar vein, I have seen two different variants of the 404632 aluminum thermostat housing. The critical features are identical (location and size of the holes, etc.) but the non-critical features -- including the location of the casting number -- are different.
Old Oct 1, 2013 | 07:39 PM
L77F85's Avatar
Tastefully Hooped
John
i have a pair of large "C's" that were on a 400G motor out of a '68 Toro.. they too have the same small crossover holes.
Tommy
Old Oct 2, 2013 | 12:54 PM
Tommy
Maybe WMachines can help solve this mystery?
Old Oct 2, 2013 | 01:45 PM
wmachine's Avatar
Trying to remember member
Tommy
Well no Toronado came with a 400 of any type. So if they came from a 400G, it would be a '68-'69 442 or Vista.
Old Oct 2, 2013 | 01:50 PM
wmachine's Avatar
Right now the elephant in the room is "what about the intakes that they are matched up to?" Are all intakes the same?
Old Oct 2, 2013 | 02:14 PM
Smitty275's Avatar
Engine Builder
This looks to be even smaller crossover hole than the small one in the pic to start the thread.
All heads have the 548, which is last 3 numbers of the part number, cast on the bottom along with the day number of year which seems to usually be in the 200 to 299 range on all the C heads I have here. And then a 2 digit which I believe is the number for the worker who layed up the cores in the foundry.
I've found no rhyme or reason as to which cross over port shows up on which motors, 2bbl, 4bbl, Toro, or 442. And I've taken a lot of them apart. Without knowing you guys had this thread going I had text Tweed early this morning asking if there was a way to determine the year of the head. Obviously there appears not to be.
Old Oct 2, 2013 | 02:43 PM
Isnt the date determined by the head boss stamping on all engines after 67? I dont know much about after 67? But I do know TORO 425s and all other 425 applications can be thrown into this mix too?
The whole casting number is 394548 -- its just that 394 in on one side of the port and the 548 on the other. As for julian dates? I have C heads with 2 digit dates ( 18) up to 3 digits in the mid to high 300's ( 365 days in the year). And Yes my true real 67 W-30 heads are 341 and 342 - right in the window of when the W-30s were supposed to have been machined and filled - during the first 2 or 3 weeks in December 1968. And they have the V code on the pass side head that verifies it as a 67 application!
So, do any of you know if all of the 68 and 69 G motors had head boss stamps in their application? Then there is the burning question of where did the "boatload" of C heads come from that Mondello pushed for years?
Old Oct 2, 2013 | 02:51 PM
Kurt -- could CFD have used different sand molds and still use the same casting number? I always thought there was a number change of some sort involved when they started using a different mold? Such as the 11 Smitty shows in one of his pix here? IMWTK!
Old Oct 2, 2013 | 07:47 PM
L77F85's Avatar
Tastefully Hooped
already solved. 400G not "originally" from a Toronado. the G block had a pivot ball mounted on the side for a manual transmission. i learned yesterday after posting the block on another post.
Tommy
Old Oct 3, 2013 | 08:18 AM
wmachine's Avatar
That is certainly a possibility. I've never seen any evidence that there was a problem with them being too small for core removal, but that type if info would not be readily apparent. I'd guess not, only because they were made pretty long with small holes and I would guess would have been changed sooner.
I'd like to add my guesses to make them larger was to get more heat to the manifold and/or reduce weight.
To want more heat there is not as crazy as it may sound and remember they were having to run in northern winter climates and needed the heat to some degree. This was just preceding the end of the divorced choke, so all of this may be related.
All guesses here.
But if the intakes all have the same holes (and they are all like the smaller head holes, heat to the intake would not really be a factor.
Right, so no application differences with the different holes.
Not that I know of.
Yes, strictly for C heads, so the date code could be used to determine the year.
Absolutely yes. And I believe that is what the 11 is, not the identity of any foundry worker.
Technically, it is a "pattern" id number, not a "mold" number. (The mold is made of sand and is expended every time a casting is made). We already know as fact that the engines have pattern numbers on them. GM even inadvertently refers to it as the "mold number" in a bulletin, but it doesn't really matter what you call it, as long as you what it is and what it means.
There can even be multiple revisions to the casting and that would not necessarily change the casting number. But they do need some form of identification for the revision.
That all said, they most certainly ran more than one pattern at a time. And those *theoretically* identical patterns would carry a mold/pattern number to distinguish it from the other castings. And that number was only used for tracking if necessary. The *casting number* would be the same, because the application was the same. Simply put, it goes the same place no matter which of the multiple patterns it came from.
To keep this from being too long an answer, suffice to say there are good engineering protocols that dictate these methods of id.
Old Oct 3, 2013 | 05:17 PM
Mikes442's Avatar
Well guys I got the CA head back. It DOES NOT have hardened seats.
Both heads have a casting dates of 114 and have the large cross over.
And are large valve heads.
I put a E head right next to the CA head and the CA head cross over inside looked to have the floor down farther than the E. ? I couldn't find a 68-69 C head yet in my stash.
The CA is 3/8 of an inch tall that are in a straight line, cast in.
I have a pair of small cross over C heads that have a date of 363 and 4.
So those are a 1967 model year head.
All my intakes including after market alum. and factory L69 3x2 have the large cross overs.
Mike
Old Oct 3, 2013 | 06:07 PM
66-3X2 442's Avatar
Mike
Thanks Mike,guess that answers that question.
2blu442
Jun 27, 2014 08:20 PM
vette442
Sep 6, 2013 06:28 PM
pcard
Mar 25, 2013 08:48 PM
2blu442
Feb 2, 2011 01:01 PM
2blu442
May 31, 2009 10:11 AM
