Diesel block in 77 cutlass
Old Jan 26, 2020 | 08:36 AM
deadeyejedi's Avatar
Is it possible gm actually used the diesel blocks in a 77 cutlass supreme as a gas application?Curious about this because i had a 77 cutlass supreme in the late 80's i bought from the original owner .It had a low end knock so we decided to rebuild it and thats when i found out it was a diesel block .Back then i payed no attention to block stampings ,otherwise i could had simply identified it from its stamping.The knock turned out to be a rod cap hitting the oil pump pickup. It was indeed a stout motor when we finished it and if i knew then what i know now yada.
Old Jan 26, 2020 | 09:00 AM
oddball's Avatar
No. There's no way the factory would have dealt with all the differences under the timing cover, not to mention the injector pump boss just hanging open. Especially considering they had the windowed 350 gas blocks which made much more sense at the time.
The diesel->gas conversion has been known for a very long time, so I wouldn't be surprised if that was one of the earlier conversions.
Did it actually have a large "D" or "DX" on the side of the block?
Old Jan 26, 2020 | 09:49 AM
I honestly dont remember what numbers were on it and at that time was only concerned with getting it rebuilt .My brother in law did the work at the garage he worked at.The original owner wasn't very mechanically inclined so i doubt he went out looking for a diesel block for a replacement ,but who knows how it got in there.thanks for the response
1570joker
Sep 16, 2016 04:27 PM
jimmyboy63
Mar 3, 2012 09:28 PM
Slater442
Jan 16, 2012 07:21 PM
jensenracing77
May 2, 2011 04:23 PM
