Determining rear end ratio
Old Jan 16, 2013 | 01:02 PM
Bitburger's Avatar
Is there another way to determine the gear ratio on a 69 Olds 98 besides removing the cover? The tag attached says only limited slip differential and shows no ratio data.
Old Jan 16, 2013 | 01:33 PM
oldsmobiledave's Avatar
Fyi
It will be a 2.56 or a 2.93.
jack up the rear & turn the driveshaft counting the turns of the wheel. If it goes around 2.5 times it is a 2.56 & if it goes around almost 3 times it is a 2.93.
Old Jan 16, 2013 | 03:50 PM
Bitburger's Avatar
OK thanks
Old Jan 16, 2013 | 03:57 PM
tru-blue 442's Avatar
Old School Olds
On the a body there is a two letter code on the axel
tube, on the pass side, between the pumpkin and shock
mount. Not sure if it is there on the b body, but I bet it is.
Could be stamped upside down as well. Check for the code
and it can be decifered through FAQ I belive.
molasses4masses
Jan 13, 2014 10:04 AM
Goat Cop
Sep 9, 2011 03:39 PM
nickd
Aug 18, 2009 02:36 PM
Greg McDonnell
Nov 9, 2008 11:48 AM
