Decklid 442 emblem hole size?
Old November 11th, 2018, 07:31 AM
Platinum69's Avatar
Does anyone know the correct hole size for the 442 emblem on the decklid of a 69? Thank you
Platinum69 is offline
Old November 11th, 2018, 08:40 AM
tangokilo's Avatar
I do not know the size off hand. But the clips go in the hole first and then the emblem is pushed on. Such that the clip then expands out and cannot pull back out of the hole. Tom
tangokilo is offline
Old November 11th, 2018, 09:10 AM
Platinum69's Avatar
yes, I was assuming that tango. Wouldnt wont to force the inserts into the wrong size hole, would be hard to get back out. Thanks
Old November 11th, 2018, 11:12 AM
442Harv's Avatar
I'm also wondering, does anyone know where to get the inserts? Can't seem to find any.
442Harv is online now
Old November 11th, 2018, 11:31 AM
70Post's Avatar
I've found them at a local NAPA Auto Parts store. They're called "tubular nuts". Sorry - don't know exactly which size you need for the trunk numerals but will try to put my hands on a trunk numeral here and see if any of these fit the mounting studs.
70Post is online now
Old November 12th, 2018, 07:10 PM
CH3NO2 LEARN IT BURN IT
droldsmorland's Avatar
The pic definitely shows the wrong design and size barrel clips. The NAPA barrel clips are the correct design but may not be the correct size. All of the Olds resto house vendors sell the correct barrels. I dont think it matters which way the clips are installed. Inserted into the body first or last. I install them on the emblem tightly by slightly closing them down so they bite into the pot metal emblem. Thus emblem removal is simple when waxing and cleaning. Pop emblem off. Wax pop it back in. Doing this for many years,
droldsmorland is offline
Old November 15th, 2018, 04:50 AM
Platinum69's Avatar
So I looked up the tubular nuts in the Aveco catalog and it said 3/16 hole, seem to work out good emblems are on.
thanks for the input
70ish
July 24th, 2019 08:05 PM
Tiger69
Vista Cruiser & Wagons
February 17th, 2018 06:45 AM
jeffu231
January 3rd, 2017 06:36 AM
Christophe2m6
October 24th, 2014 11:30 AM
JimpeBoy
June 18th, 2011 04:20 AM
Quick Reply: Decklid 442 emblem hole size?
