date coded glass
Old Jan 4, 2015 | 07:46 AM
NDERISE's Avatar
date coded glass
I will have to replace all of my glass on my car as the original glass have scratches on them that will not come out. I would like to here feedback from anyone that has replaced any glass with date coded ones and were they got them and how do they compare to the originals.
your input is appreciated thanks ray
Old Jan 4, 2015 | 08:41 AM
66-3X2 442's Avatar
Most if not all repo glass is made overseas. I've had good and bad experiences with it. I have repo glass in my car and the fit is decent. The main problem I see with thr repo glass is,if you look @ the side glass @ an angle,it appears wavy. I bought my glass here.
http://www.autocityclassic.com/
I think there is a company in Ohio that has PPG but I do not know where it's made.
Old Jan 4, 2015 | 08:51 AM
davebw31's Avatar
Good luck finding all the glass Ray. Windshields can be had with a date code (extra $$). There are some NOS available side glass, however getting a day code near your build date will be difficult. Forget finding an NOS back glass, as they are not available, and no one is reproducing them like the W/S. Check with Iowa Glass. They are the biggest. I got my dated coded W/S from them, $225 for the glass and an extra $50 (total $275) for date code. I tried to replace all of the glass for my 70' F-85 about 20 yrs. ago and could only find the RR 1/4 glass. I got a glass polishing kit from Eastwood to try to remove scratches and it worked pretty good, but it was very messy! You might have better luck since yours is a hardtop. Good luck!
BTW: your glass should be LOF stamped and not PPG. Also, it depends on whether you have tinted green glass or clear. Tinted is easier to find!
Old Jan 4, 2015 | 08:54 AM
Run to Rund's Avatar
If you want the dates and/or brand to match original stuff, you can sometimes find original glass in good condition. The exception would be the windshield which will probably be scratched and the tint discolored. I have hoarded LOF windshields I bought 30+ years ago for that reason. You might be able to find such stuff at old time glass shops, but as noted above most new stuff is from overseas.
Old Jan 4, 2015 | 10:17 AM
66-3X2 442's Avatar
The OEM glass for a 66 is LOF except for the vent window,it's PPG. Theory is the vendor for the vent assemblies used PPG where Fisher used LOF. Not sure about later models tho.
Old Jan 4, 2015 | 10:32 AM
F-85 4-4-2's Avatar
I work for PPG, and we sold both our Automotive Original & Replacement Glass businesses in 2007. We couldn't make a windshield for the landed cost of glass from China. Private equity has made a go of it as Pittsburgh Glass Works.
In 2014 we sold a residential/commercial glass plant in Mt. Zion, IL to a Chinese outfit, Fuyao. They're going to retool to make automotive glass.
I'm glad that I make OEM paint.
Old Jan 4, 2015 | 10:47 AM
66-3X2 442's Avatar
Is Pittsburgh Glass Works located in Ohio and do they make the repo glass for our cars?
Old Jan 4, 2015 | 12:08 PM
jensenracing77's Avatar
At one point I overheard Ron Memmer telling about ordering date coded glass and I am sure he said it was the side glass. You may call him and see if he could tell you where that was.
Old Jan 4, 2015 | 12:20 PM
F-85 4-4-2's Avatar
I only know their Creighton, PA plant, which was Works One for PPG back in the 1880's. I did get a windshield for my '66 there, they probably still have the molds and make them. Google 'em.
Old Jan 4, 2015 | 02:06 PM
66-3X2 442's Avatar
What is Google? never heard of that company. I don't need no stinkin glass,I'm done.
Old Jan 4, 2015 | 06:02 PM
NDERISE's Avatar
thanks for the reply's I did find a vender on e-bay. the seller is autocity1958 and he shows to have all the date coded glass if I just send him the dates needed, windshield, back glass, and all side glass for 810.00 shipped. has anyone ever dealt with this vender and if so is the glass good.
Old Jan 4, 2015 | 06:37 PM
66-3X2 442's Avatar
see post # 2
Old Jan 4, 2015 | 07:01 PM
junior supercar's Avatar
will your date coded glass also have the correct plant code for your car? It might look a little odd if your Lansing built car (assuming you are referring to the 70 W-30) with correct date coded glass was made in the Lathrop, Calif plant.
also ECS Automotive offers date coded glass. I haven't used them though
http://www.ecsautomotive.com/
Old Jan 4, 2015 | 07:10 PM
66-3X2 442's Avatar
Clarify please. What does the production plant have to do when & where the glass was made? Just curious about that statement.
Old Jan 4, 2015 | 07:38 PM
69442murph's Avatar
I have recently installed glass from AutoCity. Decent glass, but is not cut well at the top edges, you can say it is wavy across the tops. The sides are the same way. The rear qtr glass is the same way. On the rear window, you can see green spots when the lighting is on it....and the glass thickness is almost 1/2 the thickness of original.
If you do go with them or any other supplier, and have the codes etched in the glass...do yourself a favor and photograph / detail / each individual piece. Note which direction the codes read, left to right, or right to left. And are the codes on the inside of the glass or outside of the glass....
We were given a piece of paper to record all this information on, supplied it to them, and it was not followed by their personnel. All the glass came back incorrect, and then they would NOT stand behind it. When we called to complain, there excuse was "we know what we are doing and do not need to follow the spec sheet" ...what a joke....I then sent photographs of the etchings from the original to what they supplied, and 3 of the 5 pcs were wrong...We ended up buying more glass from them to get it right. They only offered a partial discount even though they f..d up....
I don't think I would buy from them again, unless I really was desperate...
Just my 02 cents worth....good luck....
tim
Old Jan 4, 2015 | 08:00 PM
Paladin31's Avatar
Ray just for giggles, what date code are you looking for, if you could post a pic of the door & qtr glass 'codes etc..' you need I would be interested to see if I might have any matches.
Brett
Old Jan 5, 2015 | 11:21 AM
dc2x4drvr's Avatar
The PGW (Pittsburgh Glass Works) windshields are awesome compared to the chicom crap. Don't know if they'll date code though.
Old Jan 5, 2015 | 11:47 AM
F-85 4-4-2's Avatar
I'd go for a new windshield and backlight, and do the etching/sandblasting yourself. New glass shows so well. Something like this:
http://nebraskalandtbirds.org/sitebu.../birdsbugs.pdf
Unfortunately, I gotta believe that any new replacement glass is going to be marked by its manufacturer, to meet DOT regulations.
Old Jan 5, 2015 | 03:36 PM
NDERISE's Avatar
tim
THANKS 69442murph this is the kind of information I am looking for, so If I speak with them before they date code anything, I want to know if they back up there work and products thanks
Old Jan 5, 2015 | 04:48 PM
NDERISE's Avatar
Brett
o. k. brett (paladin31)here your pics u requested let me know if u have and could someone elaborate on how u read the glass markings.
thanks ray
Old Jan 5, 2015 | 06:47 PM
costpenn's Avatar
I used Pilkington for my windshield. Glass came very well packaged, and the guy I spoke with was very knowledgable about the date coding system.
Old Jan 5, 2015 | 06:50 PM
66-3X2 442's Avatar
The Y is October,the V is 1969. Not sure about the 4 but the AS2 is the designation for tempered side glass.
Old Jan 5, 2015 | 07:00 PM
that 4 would be the glass the plant was made.
AS2 is also for the rear glass. basically everything but the windshield, which should be AS1
Old Jan 5, 2015 | 07:13 PM
66-3X2 442's Avatar
Yes,AS2 is for tempered glass and AS1 is for laminated glass. The windshield is laminated glass. I thought the 4 might be the plant code but couldn't find a list of plant codes. It would make sense that the glass plant used would be the closest to the assembly plant but not a guarantee.
Old Jan 5, 2015 | 07:36 PM
yep, that's what I eluded to earlier
my 70 Pontiac, built in Fremont, CA has a windshield with a plant code of 10, Lathrope, Calif plant. The car was sold new in Pontiac, IL
here is some glass info, http://www.camaros.org/glass.shtml
Old Jan 6, 2015 | 12:35 PM
davebw31's Avatar
WoW great info. I knew how to read the glass markings, however all the other info was very informative, thanks!
I did have at my desk a book on bulletins, updates, how to read the markings for both LOF and PPG. I do remember it did also include number codes where the glass was made I.E. plant location. Of course one of many files I did not take when I left. Who knew?
My 2 cents: I would only buy NOS or really good used glass. If your spending serious $$$ I would not use the current manufacturers especially those from China or those owned here in the USA. I would try the Eastwood Glass Polishing Kit first. I practiced on some glass before I did mine. Took out most of the noticeable scratches. I did replace my back glass with one that had fewer scratches and of course my W/S from Iowa Glass, date coded. I never had points deducted for my glass condition. My car had the AO2 option, which was "Windshield, Soft-Ray Tinted". All other glass was non-tinted. Tinted glass is easier to find. Is all of your glass tinted? I have several sets of tinted door and 1/4 glass from southern hardtop cars, so they are in pretty nice condition. Don't know the dates. Most came from Lansing built cars.
Good luck with the glass thing Ray!
Old Jan 6, 2015 | 01:08 PM
NDERISE's Avatar
Thumbs up Thanks
Thanks for all the commints and info. On glass, i think i will try to find someone to buff out my original glass. I do have to replace the front windsheild as it was cracked and was a replacement one anyway
thanks again ray
jim larson
Apr 1, 2016 02:13 PM
#171Cutlassman
Jan 28, 2011 06:45 PM
#171Cutlassman
Oct 25, 2010 08:06 PM
monzaz
Drivetrain/Differentials
Jan 28, 2010 12:13 PM
1BAD68"S"
Feb 15, 2007 07:38 PM
