Dash lights will not come on.57/98
Old Oct 5, 2009 | 12:30 PM
Fletch's Avatar
Has anyone out there had a light problem in the dash? Pulled headlight switch and found 3 amp fuse blown. Replaced fuse, still no Dash Cluster lights. All other lights, interior courtesy work, High beam indicator works as well as all external lights.
Headlight switch does not looked burned,nor does the reistat looked baked; Is there a hidden ground for the cluster lights alone ???
I have the manual(do not see a sperate ground).
Regards,
Fletch
Old Oct 5, 2009 | 02:16 PM
citcapp's Avatar
Just a thought, when I bought my 57 the dash pod lights did not work, tried everything up until I replaced the lamps. Thats right all of the lamps were burnt out. Might try replacing one and see what happens
Old Oct 5, 2009 | 05:48 PM
Fletch's Avatar
Thanks Citcapp... Have not gone that route.. Pulled one and looked good... I will replace them ALL.
Regards,
Fletch
Old Oct 5, 2009 | 09:22 PM
PAULIE's Avatar
hey fletch. I have a 67 cutlass suprerme with the same problem. Havent had time to mess with it but Ive been told there is a ground for the cluster . supossed to be under the dash on the drivers side under the light switch. connects somewhere behind the cluster. hope this helps
Old Oct 6, 2009 | 06:16 AM
Fletch's Avatar
Thanks Paulie, I will start rummaging around, after I replace all the bulbs.
BoutTime68
Jan 19, 2014 08:29 AM
scooter123
Sep 28, 2013 07:32 PM
Tedd Thompson
Jun 5, 2012 09:50 AM
squirell
Site Help
Nov 20, 2009 10:24 AM
