Damsel in Distress Carburetor Help
#81
I dont even want to drive the cutlass tomrw
Ok I can fix the idle, but are they both suppose to be all the way open...even the larger ones in the back...not sure if ur understanding what I mean....
But I nvr run out of gas...I watch the miles as well...Normally I drive all the way to work and back and still have gas..Im just not understanding how I ran out..I been using the same Shell Unleaded Plus...cause the cheaper gas sucks *****...
#82
The only butterfly that should be open all the time on your current carb is the front top. It needs to be straight up and down. Your fuel economy could have changed dramatically because in Texas and other parts of the country there are 2 blends of fuel. A winter blend and a summer blend, it reacts differently with temperature. The winter blend tends to get better fuel mileage than the summer. I run Valero in my car and it performs well. You do not need to be running the higher octane. Be careful not to run E85 in your car as I saw it is available in your area.
#84
The secondary air valve, which looks like it would be the "choke" of the secondaries, should never be open, as far as you can tell.
It only opens under conditions of high load (high air flow), which you cannot see unless you are driving (with the air cleaner on and the hood closed).
If it is open, then the secondary metering rods are lifted out of the secondary jets, and you have a major fuel blow-off occurring.
#85
Could be the diaphragm is leaky, or maybe it's as simple as the vacuum hose is disconnected. You can try sucking on the end of the vacuum hose to see if the diaphragm pulls in. If not, you should be able to buy a replacement at the parts store. NAPA is usually a good source for these type carburetor parts.
#86
I think we were all concentrating on the choke so much that we missed the fact that the secondary air valve is tied open with zip ties too. It also looks like the vacuum actuator for the choke/air valve may be broken or damaged. The vacuum source for that is supposed to pull the choke open and release the high idle when the throttle is stepped on after warm-up. It is also supposed to lock the secondary air valve shut so you cannot engage the secondaries until the engine is at least partially warmed up.
Neither were tied open in the original pics you posted of the carb so if the knuckehead that "adjusted it" did that, you need to avoid him at all cost from now on!
Having that air valve tied open may indeed cause a drop in fuel mileage. It could also cause low idle speed and stalling because of being over rich. You need to find someone with better hands around your intake!
#87
Holy crap, I didn't even notice that the secondary air valve was open in that picture!!
Duh.
One thing, though: The vacuum diaphragm does not hold the secondary air valve closed (well, it does, but only to keep it from "chattering" or "flapping") - the secondary air valve is held closed by the secondary air valve spring, which is located in the pivot on the passenger side. The tension on this spring is adjustable, so that the secondary air valve moves just right.
+1: If the guy who you had look at your carburetor used nylon ties to hold your secondary air valve open, he is an idiot, and must be avoided at all costs.
Duh.
#88
Guess I should have said that the air valve op-rod is tied in a stationary position 'cause the ties in the pic shouldn't cause the air valve/secondaries to be open. Kinda makes me wonder if there is any extra zip ties or other hardware on the other side of the carb. Do you have any pics of the other side Gurlie Gurl?
#89
I keep looking at that pic and enlarging it to look at different things and then editing my posts. It looks like the zip tie around the air valve op-rod may be binding enough to hold the valve open. You need to cut those things off! If the choke doesn't stay open on it's own, that needs to be fixed but not with a zip tie! Maybe you guys that deal with carbs more than I do can tell us if that choke set up is supposed to be vacuum operated and the vacuum source should go through a temperature controlled valve?
#90
Got it thanks great stuff
I went to bed SOOOO mad last night!!you all confirmed my very thoughts...
There used to be a small coat hanger wire twisted on top of one of the rods....when the carb orlieys guy saw it he removed it..added the blk ties..adjust the idle and another something...
Ok So Now you know why....I really am one of those kind of chics that's picky about who I let under my hood...he had me fooled..he actually works at Orileys.....I will see him this weekend and let him know too in a very kind way..
BUT yeah wont be touching the carb....the hood...the door nada...
But I have learned so much more about carbs this week...reading and reading...pictures and more reading...you don't know how many times I read you alls advice...until fully understand...
That's why Ive been going thru so much gas the past few days....Ok
Like I ust want to call in today to work....hmmmmm how much vacation time do I have...Im going to be like a bad junkie at work today..I just wanna go fix that crap..ayayayayaya
#92
I apologize, when I saw that the choke was tied open in the picture you posted on the previous page, I also did not see the secondary butterfly open. My suggestion is to find another carb and I would use a Rochester. It will work the best with the best fuel economy with the least investment.
#93
The choke operating spring in that year sits inside of a round housing on the side of the carburetor, attached to the choke operating rod internally.
There is a small vacuum bleed into the spring chamber from the carburetor venturi, which pulls outside air in from within the air cleaner housing, at the back of the carb, through a tube to a well in the intake manifold that sits in the stream of the exhaust crossover, where it heats up, then into the choke spring chamber, where it heats the choke spring up, which pulls the choke open.
#94
The choke is not vacuum operated, but it does use vacuum.
#95
#96
I saw your Thread tonight and just wanted to let you know I live in San Antonio and do quite a bit of work with Olds and Quadrajet Carbs in particular. Contact me if I can help as I hate to see you spend any $$ needlessly. I have correct year Carbs for your car if need be, and advice is free.
Danny
Danny
#97
I also do not see the little tab with three holes that is used with the divorced choke setup, and am not intimately familiar with all of the possible linkage variations, so I can't tell you whether this is a divorced choke carb on a non-divorced choke manifold,
or whether this is a non-divorced choke carb with its choke spring chamber missing.
Either way, as you correctly point out, the choke ain't gonna work on this car.
#98
That secondary butterfly was open ALL THE WAY LAST NIGHT like it was stuck...this morning I went and put the wire back around the top rod to keep the 2nd btrfly closed....hopefully that will work for now..BUt I did drive him to work again today..
and I didnt see the gas gauge drop in fuel either
#99
I attached a picture of the spring that holds the air valves closed (middle of 2nd row). The rod keeps the air valves from opening, it does not close them. That is done by the spring. The rod keeps them closed under high vacuum situations, like idle and low speed operation. When you accelerate hard, the vacuum drops and the rod moves toward the rear and allows the air valves to open. The vacuum diaphragm (2nd row, right side) is what controls the opening.
#100
I wish you were closer, I would fix ya up real quick. Qjets are easy to fix and tune when ya get to know em and $ friendly in the long run. Get that thing off and mail it to one of the members to fix it up for ya.
#103
I received my manuals...ANOTHER EXCITING DAY FOR ME!!!!
its like xmas over and over...but I am actually getting something to open...
Thanks....Happy days are ahead!!!!
I think its time to call in sick to work for a few days....
#104
That carb is odd. I've never seen one with that choke set-up.
Where is the fast idle adjust at? And wouldn't that tie prevent the base idle speed screw to be ineffective(fast idle cam)?
Those rear air doors should NEVER be open when it's not running. Should open and close with no sticking/binding, and should "snap" closed from wide open with NO help. Maybe varnished/gummed up or weak/broken/misadjusted return spring.
Greg
Greg
#105
Put it back the way it was
Mdchanic...cjsdad....brown7373, All you guys are right about the spring missing that controls the secondary, the orileyscarbguy - he mentioned that too me as he untwisted the metal tie that was keeping the secondary closed..then he added the blk ties..he also mention 1 or 2 hoses were missing that lead to the back of the carb
This morning before work I tied a wire back where it was before the orileys guys took it off...on the top rod to keep it closed..I only used about $6.50 in gas today...
Also german69 I wish you were closer too..anyways where are you
trueblue442 -eric I contacted that 70w dude
But who knows I may just get a wild hair and try and tackle myself..Ive always done things on my own why stop now...I dunno will see..I have some badazz manuals now that I started reading today so I have 2 more days till Friday to read and review...
#106
The carb. manual and chapter are pretty clear.
Read about it with the carb right there so you can look at it and mess with it, and then let us know if you have any questions.
As for the secondary air valve return spring, the odds are that somebody loosened the set screw and released the spring tension. It can be readjusted to spec with a bit of trial and error.
#107
So I will need a spring then..hmmmmm
Yes I started with the 72csm...geez my eyes and brain were tired after work...but I covered a lot...tmrw I will review again...certain areas of the manual....
Mmmm someone once told me to throw away my Chilton and get a REAL csm...I giggled to myself when I read that part...ahhhhhh ouuuuuu ouuulala ...he was so right.....
#109
you know whats funny to me...I have never let a man or any man tell me what to do...
And now all the sudden I have like 4 telling me what to do...the funny thing is I AM LISTENING....awww theres hope foe me yet....me smiling at myself...
#110
No Eric is GONE...I remembering him pointing that out..also went back and looked at my pictures...its not there...u can see in one of the pics I posted the spring is missing...
#111
I'm not telling you what to do. I'm just giving you information so you can figure out what to do for yourself.
... Which is what makes you different from at least 80% of the people on here asking questions:
You're looking for knowledge, not instructions.
... Which is why I'm nice to you, but I'm a jerk to people who want me to take them by both hands and show them where their own butt is.
#112
It's wrapped around the secondary air valve shaft underneath the little projecting lug on the Right side. You can only see it if you turn the carburetor upside down, and even then it's easy to miss.
It's about a quarter inch in diameter and less than a quarter inch long.
#113
I know I know Eric..Im just having fun with you all....ok ok ok...(*--*)...but its great stuff I am learning you guys...Like Ive said before I am grateful and some how shall repay some how..thats the kind of person I am..the way my dad taught me to be..when people are nice to you treat them in that manner..if they do something for you..then do something for them in return...
#115
To add to what Eric posted above, typically you would put the screwdriver on the tension adjusting screw (Step 2) BEFORE performing Step 1, to hold the screw in place. This prevents the spring from unwinding when the lock screw is loosened. This may not be an issue for you since it appears that your tension adjusting screw is unwound beyond the minimum tension required to keep the secondary air valves closed. Also, when adjusting the spring tension, a little adjustment goes a long way. 1/8 turn can make a significant difference in the secondary air valve opening rate.
#116
Downloading downloading...before the network blocks me....this morning I was blocked out from downloading anything....
oops....But making progress...Buzy more with all the School testing every where..
#117
this weekend
Also MDchanic the orileys guys I remember he even fingered the spring looking and feeling for it....I will look again today..but are we talking about the same spring...just want to make sure...the spring in question is on the outside of the carb for the vacuum rod for the secondary
this weekend
#119
maybe you can see what is there if you hold a mirror and good light under it. Here is a picture of what you should see from underneath.
The spring coils are wrapped around the adjusting screw and a loop hooks around the long narrow pin on the left. The screw that tightens the adjusting screw has a hex head and you tighten with an allen wrench.
So, if everything is there and not gummed up, you close the air valves and turn the adjusting screw 1/2 turn from when the spring hook just contacts the pin. Holding it in place, you tighten the screw from underneath with an allen wrench to secure the spring.
