cracked steering wheel
Old February 1st, 2012, 03:36 PM
pitfield1's Avatar
I just picked up a nice original for my 69. However there's a crack that needs to be repaired. Does anyone have any ideas on how to properly restore this?
https://classicoldsmobile.com/forums...139204repaired.
https://classicoldsmobile.com/forums...1&d=1328139204
pitfield1 is offline
Old February 1st, 2012, 04:02 PM
DeltaPace77's Avatar
This is a fairly common problem, but it's usually on the rim. Believe Eastwood sells a repair kit. Recall one of the weekend TV car programs, like Hot Rod TV showing how to do this. Good luck.
DeltaPace77 is offline
Old February 1st, 2012, 05:59 PM
501Paratrooper's Avatar
POR15 also has a repair kit.
501Paratrooper is offline
Old February 2nd, 2012, 08:46 PM
Tedd Thompson's Avatar
I did mine myself. Actually I took a look at what Eastwood kit was comprised of and took a inventory of what I had on hand made a few substitutions and went from there.
I used a epoxy paste called PC 11 which is white in color, same as my finished steering wheel was going to be. I then opened up all of the hair line cracks that were to small to except the paste filler and filled them to a little more than the diameter of the wheel, let it set overnight and carefully sanded the epoxy till I couldn't see the patches anymore. I then applied two coats of SEM etching primer and top coated with polar white enamel with a hardner added. Passed inspection at the Old's Nationals no point deductions.
Not that hard a Job if I can do it .......Tedd
Tedd Thompson is offline
Old February 3rd, 2012, 03:23 AM
pitfield1's Avatar
Perfect, thanks for the help everyone.
PIT 69 442 convert
Old February 3rd, 2012, 05:10 AM
miked's Avatar
I just started on mine. As Tedd said, open up the cracks (I use a 3-sided needle file). Since I have some in stock I plan to try the POR 2 part epoxy. I'm not sure how good it will adhere but it worked ok on my console repairs. Good luck...
miked is offline
360scamp
January 9th, 2011 03:38 PM
KRICHEN922
December 5th, 2009 09:39 AM
gearheads78
June 18th, 2009 06:22 PM
ziff396
Drivetrain/Differentials
February 13th, 2009 04:56 PM
Jamesbo
January 10th, 2009 06:49 AM
Quick Reply: cracked steering wheel
