Cowl Repair Panel
Old Aug 4, 2009 | 07:33 PM
malibu406's Avatar
Cowl Repair Panel
The parts place has an upper cowl repair panel part no. BP5542T (for 68-72 cutlass/442). It states that it replaces the lower window channel. I've seen a post, either here or somewhere else, that seemed to imply it also replaced the black metal part of the dash.
Has anyone used this panel? If so, how much did it cover and did it fit correctly?
I am restoring a 69 442.
Thanks in advance.
Old Aug 5, 2009 | 02:57 AM
Yellowstatue's Avatar
Smile Cowl panel
68tom was doing a repair on his '68 cowl a while ago...check his writings
Old Aug 5, 2009 | 04:07 AM
Bluevista's Avatar
Registered
There are some pics in this thread of a cowl repair panel thanks to oldsconv.
https://classicoldsmobile.com/forums...air-panel.html
Old Aug 5, 2009 | 07:03 AM
68Tom's Avatar
It's not correct. It's basically a strip that sits in the window channel, and I believe a little bit of the lower dash, although since it didn't fit properly, I'm not really sure.
We ended up using a cowl piece from a '68 Chevelle. It matched up almost perfectly.
You're better off searching the dry states for a cowl piece and upper dash (if yours is bad). That or you can get a really good body man to fab the pieces for you and weld them in.
And don't forget your VIN tag if you replace your dash!!
Old Aug 5, 2009 | 09:44 PM
malibu406's Avatar
cowl repair panel
Thanks for the information guys. The pictures really helped. That panel is going to be hit or miss for me because the previous guy cut the lower channel out about 1/4" onto the metal dash.
He gave me a cowl panel from a 72 skylark cut out from weld to weld (including the cowl tag), that will probably work. However, I'll still have to fit a small piece to make up the gap.
I'll keep an eye out for a donar cutlass with a good cowl while I work on other areas. Maybe I'll get lucky, but I have not been too lucky finding good parts here in Pittsburgh PA.
AzChevs
Oct 4, 2015 08:41 PM
8point
Jan 17, 2014 06:15 PM
meoff
Body work
17
Apr 18, 2013 06:24 PM
diesel olds
Body work
May 29, 2012 06:10 PM
nightmare
May 8, 2012 06:30 PM
