cowl decode help
cowl decode help
Hope the general section is ok for this post. Can someone help me with the decoding.
Thanks Joe
1972 cutlass supreme
Thanks Joe
Sure
You have a 1972 Cutlass Supreme 2 door HT coupe built in Freemont CA
It was body number 07205 on that production plant sequencing.
Your trim is 982 - which is a green brocaid cloth
The seat in the car is a split bench with center armrest
Body color upper/lower is code 43 - Pinehurst Green
Your car was built in the second week of March 72
Thank you for your time . One more question if you dont mind.
Im trying to hook back up my heater but cant find the spot to connect the hose on the top of the engine. One hose comes out of the heater core and into the water pump. The other heater core hose (bottom) comes out and is capped with a plug. I looked on the engine where its supposed to go but I cannot find anywhere that a hose would go.
Ill start a thread in the engine section and post the link here when im done. Ill add pics too.
*EDIT*
Link to thread about heater hoses.
https://classicoldsmobile.com/forums...tml#post360446
*EDIT*
