Correct install of notched valve covers?
Old Feb 13, 2012 | 03:18 AM
matviar's Avatar
I just installed a pair of notched valve covers on my 1970 455 engine. On the pass side, I put long notch down. On drivers side, I put short notch down. Is this correct? It seems, to maximize clearances, the notched sides should be up. There are only 2 options if notches are on the rear of the engine. Any input would be grateful! Rick
Old Feb 13, 2012 | 03:42 AM
Not sure what you mean by "down", as the valve covers can only be installed on the heads one way. In any case, notches go to the back.
Old Feb 13, 2012 | 04:08 PM
matviar's Avatar
Let me put this another way. The valve cover with the longer notch, I put on the pass side. The shorter notched cover went on the driver side, yes notches at rear at firewall. Is this correct?
Old Feb 13, 2012 | 04:29 PM
442Harv's Avatar
like Joe said,the notches go to the back, and if you put them to the back, they only go on one way.
Old Feb 13, 2012 | 04:39 PM
jensenracing77's Avatar
if i remember right the long one is for the passenger side because if the car had A/C it required a longer notch than the brake booster.
Old Feb 13, 2012 | 04:40 PM
i see what you guys are saying now. if they were on the wrong side the notches would be on the front.
Old Feb 13, 2012 | 05:30 PM
matviar's Avatar
Just wondering because I seen a picture of a w30 engine on inline tube website, and they had the notch up front on pass side behind the alternator. It was a non A/C setup. Theirs must be incorrect!
Old Feb 13, 2012 | 05:47 PM
Lady72nRob71's Avatar
They must have put the head on backwards...
Old Feb 13, 2012 | 05:51 PM
Rickman48's Avatar
And the valve cover backwards!!
Old Feb 14, 2012 | 06:37 AM
It is. Funny, since they seem to constantly win awards. This is why I'm not a big fan of judged shows.
Vega
Sep 8, 2011 05:54 PM
scott_442
Jun 14, 2011 06:58 PM
MN71W30
Apr 28, 2009 04:50 AM
MN71W30
Apr 26, 2009 07:48 PM
