Correct Ignition Coil
Old Sep 7, 2019 | 07:42 AM
roosgunboss's Avatar
1968 Cutlass S, low comp 350. Believe the ignition coil is shot and I want to replace. Only thing not stock is I replaced the points with Petronix. Old coil has no markings. Is a "use with external resistor" coil correct? (Standard 803?)
Old Sep 7, 2019 | 07:53 AM
442Harv's Avatar
With the Petronix system, I always use the coil also.
Old Sep 7, 2019 | 07:58 AM
So the "use with external resistor" coil is correct? (Standard 803?). You mean the Flamethrower coil - right?
Old Sep 7, 2019 | 08:23 AM
442Harv's Avatar
I meant to say, use their coil, has the correct resistance built in, to work with their system. Not sure what the number is?
Old Sep 7, 2019 | 08:09 PM
Tedd Thompson's Avatar
Educate me, why would you need a resister on a pointless system whether it is Pertronix or HEI? Isn't the purpose of the resistor to drop the voltage so the points don't burn. No points no burn. What I'm I missing here.... Still lost in the fifties.... Tedd
briane
Sep 2, 2019 01:23 AM
navvet
Feb 18, 2011 08:27 PM
ctrain22
Sep 6, 2009 08:37 AM
68conv455
Feb 20, 2008 02:36 AM
New'n72
Oct 10, 2007 04:42 PM
