Cool video about the '69 H/O 'vert
Old Apr 22, 2026 | 05:55 PM
72455's Avatar
1972 U code Supreme
Rare Olds
Old Apr 22, 2026 | 09:44 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
So heres some observations...
At the 19.0 second spot, the shot of the interior, I see a stick and an automatic brake pedal.
I did not know about the gold rugs or the anodized engine accessory brackets.
Old Apr 23, 2026 | 06:03 AM
GN1220's Avatar
I believe that was a Hurst Autostick. An automatic shifter to look like a manual.
https://www.jalopyjournal.com/forum/...hread.1133682/
Old Apr 23, 2026 | 09:28 AM
acavagnaro's Avatar
Great video. Thanks for sharing.
Old Apr 26, 2026 | 09:14 AM
Correct, that is exactly what it is.
Old Apr 26, 2026 | 12:16 PM
I've never understood the love affair with fake manual floor shifters. I've got column shifted manuals and automatics, and floor shifted manuals and automatics. I rarely manually shift an automatic. I can see the need to not skip past a gear when manually shifting an automatic, but, shouldn't it do it for you, considering being set up well?
I seem to recall Olds Ralph telling me it was a traction thing at the dragstrip, you spun like a mother but would hook and you wanted to remain in first during all that time.
Old Apr 26, 2026 | 03:15 PM
OLDSter Ralph's Avatar
John, it was spinning tires and going "no where" and let off the throttle to gain traction and transmission could up shift. This is likely to happen on the street or the strip. When the light changes and the other guy jumps out a car length ahead, a the trailing driver's first inclination is to press the gas pedal more. This creates more tire spin and watching the other guy pull ahead of you more. By this time, this time the race is over.
By keeping the shifter in "L", the transmission won't up shift on you if you let off the gas pedal to get traction. Most good drivers learn how to feather the gas pedal on the starting line or at a green light with street tires.
On the street I always loved the guys with jacked up rear ends or "nose down" because they were shifting weight from the rear wheels to over the front wheels. The last place you need weight removed is the rear wheels on a higher horsepower car.
Cosmic Charlie
Feb 11, 2025 02:59 PM
Cosmic Charlie
Dec 19, 2022 05:38 PM
herkguy
Mar 28, 2022 05:58 AM
442craig
Jul 16, 2014 11:33 PM
Rickman48
Jan 14, 2012 08:08 PM
