Convertible Owners!
Convertible Owners!
Hey, all.
Just a query on everybody's convertible top lowering procedure. I usually lower the top most of the way (maybe about 7/8s) so it sits about two feet high in the well and then I go back there and pull out as many wrinkles as I can and generally smooth everything out so it lies as flat as possible. Then I lower it the rest of the way. That's the way my dad did it and his dad before him (for all I know).
But recently it occurred to me that most of my dad's convertibles were manual tops. So here's the question: does leaving the top partially up for a couple of minutes while I sort things out cause any excessive stress on or damage to the hydraulic cylinders? How do you guys put your tops down?
You put your top up. I never heard of such a thing.
I have a 71 cutlass convertible. I just use the switch to raise and lower. I will admit to that is an older top with some small rips starting. With a new top I might be more careful. My Father has a Miata with a manual top. You have to move one of the ribs around as you are putting it down for it to work properly.
I don't think you are hurting anything by stopping for a couple of minutes to smooth things out. I wouldn't leave it like that over night. It might help keep your top from ripping but I don't know.
You are lowering the top correctly - it's been many years since I've looked, but I think that is how it is described in the manual, and is also how I lower the top on my car.
You will not harm anything by leaving the top partially down.
I do it the same way, and that's because that's the way my dad did it! I also put the hooks in so I can install the boot after the top is all the way down.
Randy C.
Randy C.
Last edited by rcorrigan5; October 4th, 2017 at 12:55 PM. Reason: consideration for the boot, too
I never do that and I hav two brand new tops. Interestingly one top I leave down almost all summer and then pop it up in the late fall and it usually stays up until late spring. Seems like it is just fine. The other one (on Cutlass) goes up and down all the time) the upholstery shop who just did the Cutlass top says you put the top up and the end of the day all the time. Keeps it from wrinkling.
Have had my '65 convertible since '74, always have top clean before lowering and if it has a plastic window I put a thin towel in where the window folds. If I leave the top down for extended time I put the top most of the way up and leave it in the sun for a while to let it warm up and stretch. Managed to crack windshield once by trying raise and lock down top after it had been down for few weeks.
Thanks guys. I guess I'm doing the right thing.
I never stopped to consider that I might crack the windshield by putting the top up cold, though. Thanks for that!
And thanks to Jaunty for the top manual post. I think they'd stopped providing those by '69.
Wow I never thought of that as most of the time I need to use some decent leverage to get the top to move that last 1.4 inch to lock. Lately I just close it all the way, leave it sit over night and lock it the next morning if need be or just lower it again.
I Remember reading the folding tip when I had my 1971-CS convertible (1982-1993).
I did not have a garage in Massachusetts, so every night the top went up.
Every morning the top went down.
I did not like to do the Extra folding steps, so I Cheated.
After getting on to my local street, I would drive at 3-5 mph down the road, very slowly.
Then I would put the top down (Don’t try this at home, I was a kid).
The light wind would push the folds towards the trunk and the roof would close nicely.
With the engine Running, the small 62-Amp alternator would make the roof close much faster than on battery.
I now have a 1969 442 "Rag-Top", project car.
It needs everything. The 30-year-old roof is literally a bunch of rags.
If I do put a new top on it, I think I will just follow the instruction manual.
My Miata takes only seconds to lower after the back glass is stowed if your Dad's doesn't it's out of adjustment somewhere. These things are noted for quick and easy up and down of their tops..... Tedd
I have had two 66 convertibles in my life.
I always check the folds when droping the top and put a towel on the plastic window. Never leave the top down overnight and gently pull down the front when locking down.
Wayne
Wayne
evans_78
March 20th, 2013 01:46 PM
alwayscode390
November 10th, 2011 10:35 AM
