Console Vacuum Gauge '69 442 4 speed
Old Sep 7, 2019 | 10:08 AM
alburk's Avatar
Was a console vacuum gauge an option on a '69 442 4 speed...If so I think it would mount where the Oldsmobile emblem is?
Old Sep 7, 2019 | 10:16 AM
I don't think it was. I think the last time it was an option was 65, and I think the consoles didn't change much till 68, so it would bolt up. That being said, if you got one, a flat surface is a flat surface, so you could put it there.
Old Sep 7, 2019 | 10:30 AM
Bfg's Avatar
Bfg
Actually the 64 and 65’s had the tach. and the 66’s had the vacuum gauge. Four speed consoles from 64 thru 69 were the same.
Old Sep 7, 2019 | 11:00 AM
^^^THIS. The top plate casting is the same for all years. The rocket emblem simply bolts in place over the holes that were used for the tach and vacuum gauge in the early years. Some folks have retrofitted the vac gauge, but it was not factory in 1969.
Old Sep 7, 2019 | 01:59 PM
alburk's Avatar
Thanks for all of the replies.
nonhog
Mar 20, 2019 01:54 PM
Chuck_66
Jan 6, 2012 07:51 AM
defiant1
Aug 2, 2011 10:17 AM
wmachine
Dec 18, 2010 09:30 PM
Chumley
Aug 21, 2006 10:56 AM
