Console for a dual gate shifter
Old Sep 18, 2024 | 07:08 PM
rmicciche's Avatar
I have a dual gate auto shifter that came in a box of parts when I bought my 72 cutlass. I would like to install it, but have no console. Can a Dual Gate Shifter be used with a standard Auto console, or is there a specific console for a dual gate?
Old Sep 18, 2024 | 07:26 PM
4speed455's Avatar
The original console can be modified to accept the dual gate shifter, that’s what the factory did. That’s what I did. They only made one console then adapted them to fit the dual gate or the 4 speed shifters. There are lines on the console to show you were to cut them. There is also factory documentation that details the process. There are plenty of threads on her showing the process.
Old Sep 18, 2024 | 07:50 PM
70Post's Avatar
Where are you located?
Old Sep 19, 2024 | 08:18 AM
rmicciche's Avatar
That is exactly what I needed to know, Thank You!
Ray
Maryland
Old Sep 19, 2024 | 09:03 AM
70Post's Avatar
Here are some pics showing the Hurst Dual Gate cut out lines. As Joel mentioned above, there are lines molded into the plastic on the backside.
The console shown may look odd in the floor shifter area but that's b/c it was broken up in that area and I started to repair it for the regular auto floor shifter. Figured it would make a good console for a Hurst Dual Gate since cutting it out for that would eliminate the broken areas I was repairing.
Old Sep 19, 2024 | 07:20 PM
Cut slowly or the plastic will melt due to the blade friction. I had to stop using a jig saw and go to a hand saw.
Old Sep 20, 2024 | 10:46 AM
ajr2820
Nov 30, 2023 06:28 AM
Rca
May 31, 2021 10:02 PM
stevw
Feb 12, 2014 11:24 AM
oldsmobilty
Dec 19, 2013 04:07 AM
oldgold
Feb 1, 2013 11:58 AM
