Considering swapping 324
Old May 12, 2014 | 04:37 PM
elbole's Avatar
I have a 55 super 88 sedan that I have to pull the engine out of to check bottom end "ticking" noise.
I happen to see a guy with a 394 on craigslist (out of a 64 with 30K)....comes with the slim jim too. I am considering picking up that motor and swapping out the 324 for the 394....Has anyone done this? Mounts are the same right, front?
Any advice or info would be greatly appreciated.
thanks
Old May 12, 2014 | 07:45 PM
redoldsman's Avatar
Proud Viet Nam Veteran
If you do that you sure don't want to use the slim jim.
Old May 12, 2014 | 08:46 PM
Tedd Thompson's Avatar
First give Tony a call at Ross Racing he knows more than anybody on this type of swap. Yes it can be done but there is a lot more to it than just pulling the 324 and dropping the 394 in there. The 55's slant pan is a much stronger transmission and doesn't come with all the engineering problems that the Slim Jim does. I think the front mounts will work (there may be a height difference) but not the rears....Tedd
Old May 12, 2014 | 10:46 PM
64Rocket's Avatar
Should bolt right to the slant pan trans. i'm not sure about the flywheel set up.
tony at Ross will have the info.
What is your location?
Gene
Old May 13, 2014 | 06:54 AM
elbole's Avatar
Guys thanks for your great input.....the reason I'm considering the swap is that the 324 is going to need bottom end work (due to sitting too long). Im guessing that work will be around the same $ as obtaining a newer drive train.....hence the Olds 394
By the way I'm in So Cal about 10 min from Mexican border
Old May 13, 2014 | 07:35 AM
barnfind's Avatar
Tree Row Hunter in N.D.
http://webpages.charter.net/dhomstad...me1Source1.htm
Also alot of good info
http://www.jalopyjournal.com/forum/t...elated.149650/
jpc647
Sep 21, 2011 08:51 PM
stetzie
Feb 3, 2011 05:27 PM
Barsteel
Sep 17, 2010 01:51 PM
iuhoops83
Jun 3, 2008 07:36 AM
Jeffn
Aug 6, 2006 07:16 PM
