compression ratio
Old Feb 8, 2020 | 07:06 AM
442gs's Avatar
compression ratio
what is actual comp ratio on a stock 67 442 with a 400
Old Feb 8, 2020 | 08:51 AM
The advertised CR was 10.5:1. Actual CR from the factory is usually a couple of points lower, as the heads typically ran on the high side of blueprint chamber volume. This was to allow the heads to be surfaced when being rebuilt and not push the CR up too high. Of course, if the engine's been rebuilt, all bets are off. Milling the heads increases CR, but if the stock steel shim head gaskets are replaced with thicker composite gaskets, the CR will be lowered.
marty59
Jun 11, 2018 10:55 AM
72cutlassdog
Sep 2, 2016 05:07 AM
Koda
Feb 23, 2015 12:29 PM
1969w3155
Apr 28, 2011 08:49 AM
OLD SKL 69
Jan 22, 2008 08:11 PM
