Clunk noise from front driver side (Z bar?)
Old Jul 3, 2022 | 10:59 AM
W-27's Avatar
I am at a loss. I just whent thru the entire front end and tightened all the bolts to factory specs (motor mount bolts were loose) but i am still getting a clunking noise when i take off but it is not all the titme, if i take off very slowly there is no noise if i take off like a muscle car i get a clunking noise coming from the front driver side. I am thinking that maybe the Z bar bushing are worn out and need replacement. I just replaced the uppoer bolt joints and the sway bar bushings. I just cant figure it out. Any help is much appreciated.
Old Jul 3, 2022 | 12:10 PM
fleming442's Avatar
Bad motor mount
Old Jul 3, 2022 | 12:55 PM
Bad motor mount
An absence of any sort of body torque is another indicator of this. Does it twist any in front like it has power when you take off hard?
Old Jul 3, 2022 | 02:00 PM
W-27's Avatar
All the motor mounts are fairly new but that doesnt mean they are good either. How do i determine which one is bad?
Old Jul 3, 2022 | 02:29 PM
Have you checked the rubber body mounts?
Old Jul 3, 2022 | 02:45 PM
W-27's Avatar
Rubber body mounts are brand new so i dont think that that is it. The passenger side engine mount bolts were loose so maybe that is it. Funny because i replaced all the engine rubber mounts and transmission rubber mount about 10000 miles ago and they didnt even need it but luckly i keeped the old ones so i have spares.
Old Jul 4, 2022 | 03:27 AM
shiftbyear's Avatar
You'll need 2 people to do the test, don't stand in front of the car.
Old Jul 4, 2022 | 07:05 AM
Andy's Avatar
A arm bushings, are they good? A bad upper A arm bushing will definitely clunk.
Old Jul 4, 2022 | 07:37 AM
Tedd Thompson's Avatar
Are you sure it is up front? Sometimes a bad front U joint will telegraph a clunk that sounds like motor mount, hard to diagnose buy yourself....Tedd
Old Jul 4, 2022 | 09:39 AM
W-27's Avatar
I checked all the bushings and the front motor mounts and they are in great shape. U joints are in great shape as well. The suspect now is the transmission rubber mount as there is an oil leak going on top of it and i know oil will damage any rubber mount.
Old Jul 7, 2022 | 01:49 PM
W-27's Avatar
I checked the trans and motor mounts but they are ok. Now the cluncking noise happenes only when taking a sharp turn.
Old Jul 7, 2022 | 03:40 PM
Andy's Avatar
did you verify both upper control arm bushings, front and back on both sides are ok?
Old Jul 8, 2022 | 02:55 AM
fleming442's Avatar
Could be a ball joint. Have they ever been changed?
Old Jul 8, 2022 | 11:50 AM
W-27's Avatar
Ntb
I took the car to NTB for a front end alignment. The mechanic looked for the squicky squick for 1 hour. The only thing he found was the brand new upper ball joint on the driver side squicks when the front end of the car goes up and down. I greased it with Mobil 1 grease prior to the alignment. He said wait a couple of weeks so that the grease can penetrate better but if it still does it could be a defective ball joint. I would recommend this front end alignment mechanic to any one in the DMV area. You will need to make an appointment as he only works part time but he is old school and one of the nicest persons i have met in a while. It was a great experience. Bring him the torque specs and ask him to tighten all bolts to factory specs and he will. Another perk is that they only charge $99.99 and everyone else wants $150.00
Old Jul 8, 2022 | 04:30 PM
It's great to find a good mechanic who knows how to perform a proper alignment on the classics. Thanks for sharing.
Fazer
Apr 1, 2020 10:29 AM
NotDads442
Apr 25, 2018 07:29 AM
1965cutlassragtop
Suspension & Handling
Jan 24, 2013 04:17 PM
oldzy
Apr 11, 2011 07:35 AM
miti12
Alero
Jul 27, 2007 09:56 PM
