choke tube question
choke tube question
I am missing the longer tube. I see that it is a pressure fit into the choke stove on one end, What or where does the other end connect to?
engine is a 455 with Quadrajet-7041253carb
Thanks Ben...
Thanks Ben...
The other end of the long tube connects to a port at the top rear of the carb air horn, just below the air cleaner flange. All this does is provide a filtered air source, since this air eventually gets sucked into the engine after heating the choke coil. A short piece of hose (about 1" long) couples the tube to the carb port.
Thanks Joe, I should have also included the following in my first post:
I have this dual snorkel air cleaner on the engine, previous to the engine rebuild the two hoses were connected to the rear of the carb. Is that the correct connection or do they go elsewhere?
The two hoses in that photo should be tee'd together and connected to a manifold vacuum port (any port that sees full manifold vac is fine). The unconnected port from the sensor on the bottom of the air cleaner should have a hose that runs to the actuator on the long snorkel.
The flapper in the short snorkel is also normally open and held closed with manifold vacuum. Holding it closed both allows the thermostatic air cleaner system to work and lowers inlet noise at low speeds when the engine warms up. The second snorkel is only intended to open at wide open throttle to provide more airflow (you don't need it at other times) and since it is connected directly to manifold vacuum, it also springs open when vacuum goes to zero at W.O.T.
Having the second snorkel open earlier serves no purpose other than to increase inlet noise at part throttle. It certainly doesn't hurt anything to connect the hoses as you describe, just don't expect any performance increase by doing it. The second snorkel opens automatically when the engine requires that additional airflow.
rocketcouple
January 31st, 2018 10:59 AM
