Camshaft storage !
Old Aug 22, 2020 | 04:45 PM
john mann's Avatar
Camshaft storage !
Hi all, i have bought this camshaft and lifter organizer on eBay to store away a camshaft which could be a long long time, I don't want it to rust up any ideas on what to put on it to persevere it, i have some isy break in lube left over or i was thing wheel bearing grease, any ideas, thanks for looking and if you response, john...
Old Aug 22, 2020 | 05:06 PM
Sugar Bear's Avatar
Marine grease will work well, if the environment is relatively dry any grease will work well.
Old Aug 22, 2020 | 05:55 PM
john mann's Avatar
Thanks Sugar Bear !! john.....
Old Aug 22, 2020 | 05:56 PM
BillK's Avatar
You can put grease on it if you want but it is a mess to clean off. To be honest with you I have seen more parts with corrosion under layers of grease than I have seen it do any good. I have cranks and cams that have been sitting for 10 years with just a light spray of WD40 and they look just like when I put them there. What is probably more important than anything is to keep the temperature fairly constant wherever you are storing them . I keep my shop between 68 and 70 degrees 24/7/365 and nothing ever rusts.
Old Aug 22, 2020 | 07:04 PM
john mann's Avatar
Thanks Bill, we have a lower level in our house, A small door to enter the room it is about 10x5 its very dry down there, sound like that's where i need to put it, thanks for your input on this, john...
z11375ss
May 4, 2016 01:52 PM
Koda
Apr 20, 2015 08:31 AM
plonka
Nov 17, 2013 02:57 PM
Railguy
Jul 17, 2012 01:26 PM
nonhog
Sep 2, 2011 05:52 PM
