Cam Info ?
May want to make sure it's not too high of compression, you'll likely want to be running premium, likely prone to pinging on hot days when lugging around.
One thing I forgot to mention is that I believe Engle rates their advertised duration values at 0.008", rather than 0.006" (comp/bullet) or in some cases 0.004" (crane I think). Therefore, the Engle cam will look slightly smaller than others due to the way they rate it.
