a/c lines?
The AC lines are actually made by Classic Auto Air in Tampa FL. You can buy direct from them. Companies such as TPP just buy from them and resell. There are a couple of vendors for the condensors on Ebay. I also believe Classic Auto Air can supply you with a condenser as well as the o-ring kit. If you are switching to R134A, you should change all of the hoses, flush out the old oil, use 134A compatible oil and send your POA valve to Classic Auto Air for recalibration or buy one of the replacement valves. All depends on what look you want. I used this company for my 69 442 AC needs and they did a great job. I actually went a step further and sent them my old lines and muffler and had them re-use my fittings in the new lines as well as my muffler for a factory correct appearance. The new muffler on the replacement lines has a different appearance.
<mr.stew@netzero.net>
Oct 18, 2004 11:20 AM
