A/C line question
Old Aug 26, 2013 | 08:18 AM
1arunem's Avatar
A/C line question
1966 442, tri carb car. Need the A/C line from the evaporator to the receiver/dryer.. Any place to source an 'original' or correct line? I can have one made but would rather a correct one if available.
Thanks!
Old Aug 26, 2013 | 09:55 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Classicautoair or Vintageautoair dot com. If you can scrounge up a decent used hose they will install new hose and weld on the original ends.
Old Aug 26, 2013 | 10:33 AM
1arunem's Avatar
That's the problem. Someone in the past twisted one of the original metal ends off apparently trying to remove it from the dryer..
Old Aug 26, 2013 | 03:45 PM
jag1886's Avatar
Tri Carb car with air, there can't be many of those. Go fast and be cool. Sorry I can't help with your hose.
Old Aug 26, 2013 | 07:18 PM
66-3X2 442's Avatar
FYI 66 & 67 are different. I probably have one but I'm still off my feet for a while.
Old Aug 26, 2013 | 07:26 PM
I would contact one of the above-mentioned A/C companies, as they may be able to reconstruct an original-appearing line from your destroyed one.
They have the tooling to make all kinds of lines from scratch.
Old Aug 27, 2013 | 07:34 AM
The above mentioned companies have piles of used stuff for just this occasion. I used Vintage, they did one hell of a job on the last A/C car I did.
Old Aug 27, 2013 | 08:07 AM
1arunem's Avatar
Thanks for the info guys.
66 3x2 442, is your name Mike by chance? I think I spoke to you prior to picking up this car (George Howard referred me to you)..
Old Aug 27, 2013 | 08:13 AM
66-3X2 442's Avatar
Yes,this is Mike. I wish I could help but I've got a medical condition right now that has me limited in what I can do. I have a box of A/C lines in the attic of my shop and I can't get to it right now. I sent my lines/complete system to Classic Air down in Florida for service and they did a great job.
http://www.classicautoair.com/
Del70
Dec 7, 2025 02:13 AM
70 ctls
Mar 17, 2015 09:18 AM
davepnola
Dec 2, 2010 09:00 PM
Flye
Jul 31, 2009 04:03 PM
68conv455
May 20, 2008 02:03 PM
